Go to Post But if FIRST followed a "truth in advertising" philosophy for the registration kits, they would contain six cannisters labeled: "Stress", "Anxiety", "Confusion", "Insomnia", "Dietary Inadequacy", "Unbalanced Priorities" And a really big seventh one labeled "Fun" :) - dlavery [more]
Unread 11-02-2007, 03:05
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Redesign, 36mm question.
Turns out we have to resort to plan B, we have to abandon our forklift due to weight and time issues.
Luckily we have prepared for this to happen, and have built an arm incase the forklift doesn't work out, or if we want to try a different manipulator (both built from 80/20, can be switched in under 5 minutes).
Now, I was thinking about using two FP motors with the KOP gearboxes. BUT, I was also thinking at the same time that it might be overkill, and we are also starting to face space constraints. Now, we HAD 2 42mm 64:1 gearboxes for the FP motors, but we wound up returning them because we decided not to use them before we even opened the box. Seeing as this is the 6th week, and since we operate off of purchase orders, we can't sit around waiting for another order from BaneBots to come in.
This brings me to the 64:1 36mm gearboxes given to us in the kit. Could two power an arm that weighs about 15lbs max? We can reduce it even further with an 11 tooth sprocket on the gearbox, going to a 30 tooth sprocket on the arm. I think it'll have more than enough torque to lift it, I just want some input from somebody who has a little bit more experience with them, I've never ran them before.
Thanks
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 11-02-2007, 03:50
AdamHeard's Avatar
Lead Mentor
Re: Redesign, 36mm question.
I think you would need more reduction.
Also, you say the arm is 15 lbs, but how long is it, and are you driving it directly at the joint, or another location.
You can make the 64:1 work if you put a decent amount of addittional reduction, but 11:30 probably isn't enough.
Unread 11-02-2007, 04:20
Mechanical/Driver
5' long, it's rotating point is 3/4" in from the end.
To make things easier, here is the CAD drawing of the robot, minus the claw:
Adding more reduction isn't a problem. We've got room for almost any size sprocket on the arm end. Possibly a 60 tooth aluminum sprocket from IFI, making it 11:60.
Unread 11-02-2007, 08:38
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
For that size arm I believe that you are not going to get enough reduction out of the 64:1 gearbox's. I would take a look at the Globe Motors and Kayang motors, they both have more than enough tourqe to power an arm when properly sprocketed.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 11-02-2007, 10:53
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The problem that you would most likely have is that the 36mm gearmotor (or the globe) will not support the arm when not powered, the arm would fall down of it's own weight. We have a similar design, and purchased a gas spring from McMaster-Carr, which seems to do a decent job of supporting the weight of the arm. We are using a BB 125:1 gearmotor, and the arm weighs about 5 lbs total, and is about 5 ft long at it's longest. We have an 8:1 chain reduction at the arm pivot.
You might be able to use one or two of the window motors, with quite a bit of chain reduction, and have it support the arm without backdriving the motor, but look carefully at the torque it will take to lift the arm, and try to pick a motor or support the arm with some type of spring so the motor is only loaded to about 1/4 of it's stall torque (as found in the Guidelines, Tips, and Good Practices manual)
Unread 11-02-2007, 11:00
DonRotolo's Avatar
Back to humble
FRC #0832
I agree: The BaneBots trans is great, but it can be backdriven. You need to use a motor that is not backdriven, as squirrel mentioned. Some sprocket reduction - a tradeoff between power/durability and movement speed - and you should be good to go.
We did exactly that in our rookie year robot, a 12 tooth sprocket on the motor, about 48 tooth on the arm, using a window motor and the van door motor. The van door motor did the work, the window motor was there only because it did not backdrive - it acted as a brake of sorts.
Don
Unread 11-02-2007, 11:40
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
In another thread, Dr. Joe said that the 36mm may fail with repeated use with as little as 100in-lbs of torque. You want to use two, so you safely have 200in-lbs at your disposal. A 5ft arm that weighs 15lbs and is uniformly distributed weighs 0.25 lb/in. Integrate from 0-60, and you get 450in-lbs. You'll need to add more to that, because your weight is not uniformly distributed (due to your gripper at the end), and you'll have to add 60*(tube weight) to account for actually manipulating a game piece. Roughly estimating, I'm thinking that the 11:30 reduction is cutting it way too close to be safely operating your arm. A bigger sprocket at the top (the IFI 60 or 72) may work, but as others have mentioned, you still have the backdriving problem. My team is taking our chances with that, but you may not want to.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 11-02-2007, 12:28
Mechanical/Driver
So if we had 11:60 gearing on two of the motors, it could power the arm without a problem.
About the backdriving problem - would it be a bad idea to regulate this by applying current to the motors to keep it from backdriving, like the Victor's brake mode?
OR who thinks I should just abandon the idea of using the 36mm gearboxes, and just suck it up and find somewhere to mount the fisher price gearboxes?
Unread 11-02-2007, 13:04
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
http://www.chiefdelphi.com/media/photos/26796
5' long arm 2 banebot 36 mm motors, However we we are using 125:1 gearboxes with a futher 6:1 on chain.
This was done for speed tho, and torque was not the factor.
It lifts the arm no problem, back drive was a small issue but we made some modifications and now it stays where ever we put it.
If your wondering about torque, these motors can handle it. The gearboxes are something to worry about potentially, but we've been running it for about a day and not seen any of the problems that other people have been seeing. Its run enough for me to be happy with it. ( Maybe 200 cycles up and down? )
The arm weighs ~7.5 lbs with tube in tow. Its displaced over the distance of 5' b/c the pvc is like .75 lbs a foot or something, but the gripper ways ~ 2 lbs and the tube ~ 1lb.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 11-02-2007, 18:32
DonRotolo's Avatar
Back to humble
FRC #0832
Two significant misunderstandings:
To use a Victor to keep the motor still, you would need to use a feedback loop and PID control - simply because the force on the arm pivot varies according to load on the arm, and angle of the arm. No load straight up, but max load sticking out paralllel to the floor.
The Victor brake mode will not do anything for you in this case - it is dynamic braking, and its force is linearly proportional to motor speed. Zero speed, zero braking effect. Search on Victor Brake to find the thread that explains this in detial, I think it's from a few years ago.
Don
Unread 11-02-2007, 22:05
Mechanical/Driver
We are at the same weight, just about. The arm is actually going to be made of 80/20 1515 , I just modeled it as normal aluminum square tubing for sake of simplcity in seeing my design. The one 5' piece of 1515 weighs 6.7165lbs. (based on the 1.3433lbs. per foot given in the catalog), and our claw, by my guess, weighs maybe 2lbs, also made from the 1515 extrusion - so realistically, we are looking at ~9lbs. I just said 15lbs. as an overestimate - tomorrow I'll actually weigh everything out so I can have an accurate sense of how much this thing actually weighs.
I'll probably just put an order in tomorrow for a 2 72 tooth sprockets from IFI, and have them next day aired, just to play it on the safe side, 11:72 should be more than enough to lift this thing. I think we have some 60 tooth steel sprockets laying around our storage room somewhere, and we also have the 3/8" bore 11 tooth sprockets for the motors themselves, so I'll put those together real quick with those other sprockets and see if it works.
Unread 11-02-2007, 23:10
MrForbes's Avatar
AKA: Jim
one 5' piece of 1.5" od x .065" wall aluimnum round tube weighs about 1.8 lbs
Just something to think about....it would really cut down on the load on your motor.....
Unread 11-02-2007, 23:24
iR3 Creative
AKA: Dan Richardson
Ok, we've made one change, the motors and everything are fine and the backdrive was negotiable but we went to Home Depot and bought a gas spring strut typically reserved for cars. We mounted it aprox. 5" down the arm that way at the most extreme of cases the arm was nearly neutrally boyant. The motors are then able to keep the arm completely still just by putting in the pwm jumper for the " break " ( also for testing purposes shorting the motor does the same thing )
The mounting for the gas shock and all weighed in about 1.2 lbs and will greatly increase the life and functionality of our arm. Infact the gas shock was so affective it negates the need for our second motor, however we left it on because we like high safety factors. If your worried about motors wearing out or backdrive this is a wonderful solution thats overlooked and under appreciated. If you need some pictures of what I'm talking about I'll get someone to take some and send them your way.
Unread 11-02-2007, 23:31
Mechanical/Driver
This is true...I really like the 1515 due to easiness of mounting stuff with t-nuts, but you are right, using normal alumimum would take down the weight significantly. In fact I think we have some square tube just lying around in the storage room as well....looks like I'll have to start drilling mounting holes again...
Unread 12-02-2007, 01:52
AdamHeard's Avatar
Lead Mentor
If teams are worried about arms backdriving, stop.
If you have feedback on the arm (a potentiometer is the easiest) a simple PID loop will hold the arm steady.
If the PID loop is perfectly tuned, it may cause the motors to stall as it tries to maintain a perfect angle. If you're using the FPs (which I'm assuming you are) then you can add a slight oscillation. The oscillation can be so minimal it has no effect on scoring, and it is easy to do; Just have the programmers turn up the I slightly. In fact, anyone who has programmed a PID loop can attest to this, it's easier to make it oscillate slightly than stay perfectly still.
Read Matt Krass's paper on PID and you will have a much better description.
Banebots 36mm gearbox: Recommendations for use Joe Johnson Motors 2 02-02-2007 17:10
FirstCadLibrary Updated - 36mm Gearbox Ed Sparks Inventor 2 13-01-2007 17:16
36mm BaneBots Gearmotor Model Madison Inventor 5 10-01-2007 07:35
Does anyone else forsee redesign problems? Jon K. Website Design/Showcase 2 18-12-2004 18:02
Team 121 redesign its website archiver 2000 0 23-06-2002 22:00
