Go to Post I am also impressed that you maintained the integrity of your parentheses; you must be a software guy... - DonRotolo [more]
Unread 12-02-2007, 00:01
Rinaldi 427's Avatar
Rinaldi 427 Rinaldi 427 is offline
any help but programming
AKA: Angelo Rinaldi
FRC #1482 (the ghosts)
Rinaldi 427 is an unknown quantity at this point
TEAM 1482 LIFTS TWO
TEAM 1482 LIFTS THE WEIGHT OF TWO ROBOTS
team 1482 proudly Canadian. proudly student built
Unread 12-02-2007, 00:26
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: TEAM 1482 LIFTS TWO
That better be a 60 pound barbell, or else it isn't an good test.
(120 bot + 15 batt + 15 bumpers = 150 total)
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 12-02-2007, 00:34
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
Can your robot lift with only one bot on your assembly? Would the weight difference effect your mechanism?
Gabriel Goldman
PhD Candidate
RoMeLa: Robotics and Mechanisms Laboratory
http://www.me.vt.edu/romela
Virginia Tech
Unread 12-02-2007, 00:48
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
It appears that they have a piston mounted on the outside of each their "wings"... This should make the 'bot able to lift only one ally at a time.
Unread 12-02-2007, 01:50
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Most impressive!
A few questions:
What material is the platform surface?
What bore and stroke are those cylinders?
How much the bot weigh total as pictured?
Do you score points for a 4" lift or a 12" lift?
Unread 12-02-2007, 04:02
nsr's Avatar
nsr nsr is offline
nitroussuprarola
AKA: Ryan G.
FRC #2090 (P.E.T.T.)
nsr is on a distinguished road
Send a message via AIM to nsr Send a message via MSN to nsr
do you guys have an arm?
that looks unstable because the other robots have to be presice at their manuverability in the 15 second ending period
Unread 12-02-2007, 20:13
AKA: Angelo Rinaldi
The material is aluminum with honeycomb sandwiched between the pieces. 1 and half inch bore on cylinders and 12 inch stroke we go for the 12 inch bonus points. As said previously we can lift either 1 or 2 robots for total of 30 or 60 points. our bot weighs 117 pounds (picture is missing part 2 of arm and the electronics but total all "stuff" weighs 117.) and yes we have a full arm that can reach all 3 levels of scoring. our arm is quite stable and it doesn't shake at all.
Unread 12-02-2007, 23:57
Ah, I see, so that's how you make weight. Your cylinders are illegal. They are not listed on the order form. I hope you know this. Any inspector who passes it should be fired.
Unread 13-02-2007, 00:13
AKA: Angelo Rinaldi
sorry that wasn't my reply my friend made a typo there 11'' stroke but we get 13 1/2'' of lift and were good and we have had 165 lbs on each wing "i know thats what were calling them too"
Unread 13-02-2007, 00:15
How exactly does that work?
Unread 13-02-2007, 00:25
AKA: Angelo Rinaldi
ok so i installed the pneumatics so they were vertical 4 on each corner of the bot and one on each wing than we made feet for the cylinders and toed in the walls that gives us 2 1/2'' to start with 1/2 for the wall and 2 from the ground than we go up 11''
Unread 13-02-2007, 00:27
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
They could be mounted 2 1/2 inches below the surface of the lift...
Unread 13-02-2007, 01:14
Brian C's Avatar
Brian C Brian C is online now
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Lighten up a bit.
The inspectors are volunteers so firing them is not really an option.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 13-02-2007, 01:36
robotguru1717's Avatar
robotguru1717 robotguru1717 is offline
AKA: Martin Cacan
FRC #1717 (D'Penguineers)
robotguru1717 will become famous soon enoughrobotguru1717 will become famous soon enough
I think the biggest question is HOW LONG DOES IT TAKE?! We had a similar idea but ditched it when we found out the air cylinders couldnt fill up the pistons to full preasure and that the compressor took time to get the last part up. For it to be really great and functional, i believe it has to go up in under 3 seconds or at least under 5 seconds
Quote of 2007: "That nub looks cattywampus" -Amir Abo-Shaeer
(fyi there were about 50 nubs on the robot)
Team 1717: D'Penguineers
2008: LA-Regional Winner
2008: SD-Regional Winner
2008: SD-Delphi "Driving Tomorrow's Technology" Award
2007: LA-Semi Finalist
2007: SD-Finalist
2007: SD-Imagery Award
2006: Phoenix Semi-Finalist
2006: Phoenix Regional-Rookie Inspiration Award
2006: LA-Rookie All-Star Award
pic: Team 488 XBot two lifts getting closer Fred Sayre Extra Discussion 8 04-02-2007 16:58
1482 Help with Compressor Rinaldi 427 General Forum 7 31-01-2007 07:46
RINGERS 1482 Rinaldi 427 General Forum 0 25-01-2007 02:27
part shipment help 1482 ! Rinaldi 427 General Forum 0 25-01-2007 02:22
whatever happened to the good ol' scissor lifts? archiver 2001 3 24-06-2002 01:12
