Go to Post Ahhh... the beauty of an exponential series... - dtengineering [more]
Unread 11-02-2007, 20:24
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
pic: Team 401 - Teaser #2
Unread 11-02-2007, 20:26
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: Team 401 - Teaser #2
Are you planning on covering the grating on the ramps with any other (higher traction) material, such as carpet or rubber belting? As a potential alliance partner at VCU, 116 is curious.
Unread 11-02-2007, 22:35
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
The... crisscross grating thing ... that you see on the surface isn't symmetrical. If you think of them as little knife-blades, the edge points up the ramp.
I guess it's kinda like having shingles or scales, but they're put such that they'll dig into whatever your traction is a bit.
It's been a long day, I have to use analogies and generalizations...
Unread 11-02-2007, 23:25
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Did you make a flop-bot this year? I only ask because I don't spy any hinges on those ramps...
EDIT: Never mind, they just hinge a little farther back then I expected... Good Idea. Nice Design!
Unread 11-02-2007, 23:42
ggoldman's Avatar
FRC #0401
If by 'flop bot' you mean a robot that only has a ramp...than that is not us!
We have our arm ready to be mounted in between the two sides of the ramps (hence the open middle). It is a fairly light weight two stage arm, that if you add the ramp, makes a total of a 3 stage arm.
Pictures will come this week!
Gabriel Goldman
PhD Candidate
RoMeLa: Robotics and Mechanisms Laboratory
http://www.me.vt.edu/romela
Virginia Tech
Unread 11-02-2007, 23:53
DonRotolo's Avatar
Back to humble
FRC #0832
I just love that huge aluminum sprocket...
Don
Unread 11-02-2007, 23:54
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
By "flop bot" he means a bot that starts on it's side, then falls down. This is typically used in order for teams to have a longer dimesnion (the 48"/60"/72" dimension, as opposed to either the 28" or 38") driving on the floor.
Unread 12-02-2007, 00:37
ggoldman's Avatar
FRC #0401
Oh..ok..
This is still not a "Flop Bot"
The ramp is around 45" long (rounded) and sits around 15 degrees.
Our robot will be 48" tall in total (starting position)
The hinges are integrated into the frame construction and the ramp (in the axle of the sprockets.
By the way, we have two huge aluminum sprockets! One to power the ramp/truss and one to power the elbow (arm).
Gabriel Goldman
PhD Candidate
Virginia Tech
pic: Team 401 - Teaser # 1 ggoldman Robot Showcase 1 11-02-2007 01:41
TEAM 401: Scoring Arm Prototype - Point of View ggoldman Robot Showcase 15 30-01-2007 16:02
pic: Team 25 teaser CD47-Bot Robot Showcase 2 21-02-2004 17:58
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
TEam 401 contact info Andrew Rudolph General Forum 1 17-05-2002 00:24
