Go to Post I hope that kids will stop asking us if we build Battlebots and start asking us if we build Transformers. To that, I will answer with a resounding yes. - Madison [more]
Unread 07-02-2007, 23:59
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
light up buttons
I know we are not allowed to use them, but we were thinking if we drilled holes in the button itself, and had a separate operating circuit to run an LED inside the button. Somehow, we tried going on the Q and A to figure this out, but it did not work, it wouldnt let us post, so im asking here.
so, do you think that would be legal, drilling in the button a separate operating led to light the button up, yet not be part of the same circuit?
My other car is being built to go to Mars in 2011.
Bet you aint got one of these...
Unread 08-02-2007, 08:11
Re: light up buttons
According to robot rules and the IFI OI ref guide, you can use the LED outputs on the OI for anything you want as lond as they only use power from the OI LED ports which are internally limited to 10 ma. You can use the dashboard to port data to an outside self powered box that could interpret the data as outlined in the rules.
<R79> Teams are permitted to connect a portable computing device (Laptop computer, PDAs, etc.)
to the RS232 Output of the dashboard port of the Operator Interface for the purpose of
displaying feedback from the ROBOT while participating in competition matches. Please
note that AC power will not be available at the playing field so these devices will have
to run on internal batteries.
<R83> All equipment connected to the joystick ports of the Operator Interface must be powered
solely through the power available through the port. External power sources of any type are
not permitted on any equipment connected to the joystick ports. Portable computing
devices can not be connected to joystick input ports on the Operator Interface. Powerpassive
devices (e.g. joysticks that draw their power solely through the Operator Interface
joystick port) are permitted. The one exception to this rule is Innovation First Incorporated
USB adapters (IFI Part Number USB-CHICKLET) may be used to connect USB devices to
the joystick ports of the Operator Interface. If used, this USB adapter must be powered with
a 7.2V battery similar to the back-up battery. Teams can not use power from the
competition port or any other source to power the USB adapter. The USB adapter must be
positioned within the OPERATOR CONSOLE so that the indicator lights may be seen during
inspection and operation in a match.
Unread 08-02-2007, 21:47
FRC #0599 (RoboDox)
Al, i understand all that you said, but i dont think it answers my question.
Will leds inside of a hollowed out light up button, yet still has a different circuit from the button, be legal?
The mannuel states inside one of those boxes, it may be from the tip and good practices portion, that you may not use the light portion of a light up button. But, i will have the wiring to the led separate from the button, and running from the OI port from different pins on port than the switch itself. Is this legal, as maybe the rule was instated because they dont want a light up button what so ever, rather than separate the current in the switch causing an error?
Unread 08-02-2007, 21:57
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Eric, I found what you're talking about, on page 32 of the Good Practices document. However, remember that the purpose of the document is exactly the same as its name: "Guidelines, Tips, and Good Practices", not "Rules". The rules come from the manual, and as far as I can tell, LED-illuminated switches are indeed legal on the OI. My best guess is the reason for that particular "Caution" bullet point in Good Practices is to avoid teams blowing out their OI by trying to run incandescent bulbs.
(As a side note, my team is using illuminated buttons on our OI, and after careful analysis of the manual, we do not anticipate running into any trouble at inspection time.)
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 08-02-2007, 22:35
Eric,
Sorry about that. LEDs inside switches are legal when the are connected to the LED outputs of the OI as Joe has pointed out. There are some nice switches out there that have internal LEDs that can be used. You need to make sure that the LED does not have an internal resistor since the OI is already wired with the series resistor needed for powering an LED at 10 ma. NKK is one of the manufacturers I have used at work, but there are many others.
As far as modifying a non-lighted switch, I think you will find this is not an easy undertaking. Many switches have hidden metal within the insulated base that is connected to the terminals.
Unread 08-02-2007, 23:02
FRC #0599 (RoboDox)
we already soldered resistors on the leds, so we dont actually need them? The voltage i thought is 5V at 10mA, to which can run the LED for a short period of time, but since 5V leds have a 5V peak, they run off extremely low amperage when at 5V. So we are putting a resistor on to make the LED run at 10mA at 3.5-4V.
What you are saying is we dont need to do that, as in just hook the pin to the led to the gound with no resistor?
Unread 08-02-2007, 23:48
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
Just wondering could you use the power off of say, a laptop USB port; provided it was battery powered?
Eat, Sleep, Build Robots
Unread 08-02-2007, 23:54
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Only if the said LED wasn't at all connected to the switch.
Also, I think many teams would find it useful if the LED actually ment something, instead of just lighting up.
And why not just a real battery?
Unread 09-02-2007, 00:37
FRC #0599 (RoboDox)
ummmm, the leds will indicate certain codes the robot will run, and while it runs, we want to see what its set to.
so, getting back to topic, so wiring the led is simple as what mentioned before, pin to led to ground pin without resistor?
Unread 09-02-2007, 00:42
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Didn't we just establish that this isn't the case?
_
Unread 09-02-2007, 00:53
FRC #0599 (RoboDox)
well mathematically, it doesnt seem right, i just want to confirm that the statement is true, because if the math of an led is right, you dont want 5v going into it with 10mA. But if the IO automatically lowers it correctly, then ill be ok, i just wanted to make sure i was reading it correctly. i guess i am, thanks for the help. rep is on the way.
im a little pushy today, just a long rough day personally and with work(school).
thanks again
edit:
agh, wait, reread your post joey, so i dont have a confirmation if:
positive pin -- led -- gound pin
will work or if my math is correct and i need a:
positive pin -- 100-200ohm resistor -- led -- ground pin
lets just call them Circuit 1 and Circuit 2, which is the correct one?
Unread 09-02-2007, 07:30
Eric,
The LED outputs on the OI are the 5 volt power supply through a resistor. They were designed so that you don't need to add a resistor you just connect the LED straight to the OI output. (The OI REf Guide on the IFI site explains this) The internal resistor value was chosen to provide an LED current of 10 ma. If you add external resistors you will lower the LED current even more, perhaps making them so dim you can't see them. We have used LEDs on the operator station for many years to do exactly what you are asking. We have software that helps us calibrate everything on the robot and select a variety of auto mode solutions. We do not use the LED inside a switch but rather mount them individually so that we can identify them with labels. PM me and I will give you my email if you need anything further. Time is short, good luck.
It is not legal to externally power any other devices connected directly to ports on the OI except the Chicklet. You can have a custom box, powered by external power (you supply) and connected to the dashboard that can use dashboard data to display whatever you want.
<R79> Teams are permitted to connect a portable computing device (Laptop computer, PDAs, etc.) to the RS232 Output of the dashboard port of the Operator Interface for the purpose of displaying feedback from the ROBOT while participating in competition matches. Please note that AC power will not be available at the playing field so these devices will have to run on internal batteries.
<R83> All equipment connected to the joystick ports of the Operator Interface must be powered solely through the power available through the port. External power sources of any type are not permitted on any equipment connected to the joystick ports. Portable computing devices can not be connected to joystick input ports on the Operator Interface. Powerpassive devices (e.g. joysticks that draw their power solely through the Operator Interface joystick port) are permitted. The one exception to this rule is Innovation First Incorporated USB adapters (IFI Part Number USB-CHICKLET) may be used to connect USB devices to the joystick ports of the Operator Interface. If used, this USB adapter must be powered with a 7.2V battery similar to the back-up battery. Teams can not use power from the competition port or any other source to power the USB adapter. The USB adapter must be positioned within the OPERATOR CONSOLE so that the indicator lights may be seen during inspection and operation in a match.
Unread 11-02-2007, 12:53
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
Eric,
Al,
On Jan 29th, I communicated with IFI regarding their documentation being in error with regard to this, and to their credit the OI documentation was updated the next day.
See page 5 of the current documentation here: http://www.ifirobotics.com/docs/oi-r...de-1-30-07.pdf
In addition to their explanation here are some additional comments and observations...
The outputs are not derived off a 5V supply, the voltage varys as a function of the input voltage and appears to be a fairly consistent voltage drop of about 2.5 to 2.6V (as measured between the tether input and the open circuit LED output). Given that the tether power input could be about 12.5V, the LED outputs could see as much as 10V.
At competition, the OI power input via the competition connector would be about 9.9V at its lowest (confirmed with IFI), so the open circuit LED voltage would be on the order of 7.4V minimum.
When using the wall wart, depending upon the load that open circuit voltage will probably be around 8.4V (per IFI).
The resistor inside the OI is 470 ohms (per IFI). I calculate an effective resistance closer to 500 ohms, and IFI's new documentation puts it closer to 550 ohms.
Assuming 470 ohms, with a RED LED that has a forward voltage drop of 1.7V, a minimum of about 10-11mA would be available. When tethered, it could be as much as 16mA.
At the other end of the extreme, a BLUE LED with a forward drop of 4.5V would only have about 5-6mA available at competition.
Perhaps previous generations of OI's did power the LED's from 5V and the user manual never got edited.
The bottom line is that we do agree that when using the LED outputs to power LED's, no additional resistor is needed and I think IFI's new wording helps to clarify this.
--Dave
Unread 11-02-2007, 20:44
Dave,
This is a difference and not fuly documented since the OI manual you linked to, on page 7 "Notes:" states "[2] LED drivers provide 5V at 10mA". There are several other places in the manual where this is repeated. This is the criteria teams have used as far back as I can remember. If the LED outputs are indeed the raw input voltage, there will be times when the LEDs will extinguish due to low current. In the past we were told they were part of the 5 volt rail held up by the backup battery. I will pass this on to my software team.
Thanks,
Unread 12-02-2007, 02:10
Dave K.'s Avatar
Engineer/Mentor
FRC #0930
Dave,
Thanks,
Hi Al,
Good catch, they clearly missed editing the note on pages 7-9, and I'll pass that along.
I originally noted the discrepency after being forced to reverse engineer the interface to design some interface electronics and was looking into a source of power other than the +5VAux pin.
As it is unregulated, it then became important to understand more about the power that is supplied via the (undocumented) competition port, so I also pressed for answers on that and got a reasonably detailed description of that as well... and that's where the information on the 9.9V supply voltage comes from. The undocumented power pin, is parallelled with the coaxial power connection.
It appears to be fine to use as intended, except for the possibility of a situation requiring a higher voltage LED such as white, or blue.
--Dave
Green light same color as overhead light Ethulin Programming 13 02-08-2007 15:24
Multiple Light Tracking with Distinct Light Boxes MaHaGoN Programming 30 19-02-2007 10:46
red light / blue light ay2b Programming 1 24-01-2007 23:00
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
Buttons, Buttons and more Buttons (2006) Freddy Schurr Team Organization 11 14-12-2005 21:36
