Go to Post I worship whoever cleans the robotics room. - John Gutmann [more]
Unread 12-02-2007, 08:30
Re: Compressor fuse keeps blowing
Doug,
This occurs due to the high starting current of the pump, up to about 25 amps. The rules state that for the pump Spike only, you may replace the 20 amp fuse with a 20 amp snap action breaker. All should be better.
Art,
Your amps vs. volts would hold true with certain types of power supply but not with the battery. What does occur as the current increases is that the terminal voltage drops. This is due to simple Ohm's Law V=I*R, for the internal resistance of the battery which is 0.011 ohms. At 100 amps this translates to 1.1 volt drop in the terminal voltage.
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
Labview keeps freezing SHerpich LabView and Data Acquisition 31 02-02-2006 14:53
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
Time keeps on ticking /)/)/) archiver 2001 2 23-06-2002 22:12
Blowing 60 Amp fuse archiver 1999 4 23-06-2002 22:07
