Go to Post Namaste. Maybe we all one day will spend our energy trying to raise our own level to match that of the competition rather than trying to tear others down. - Rich Kressly [more]
Unread 12-02-2007, 09:04
N7UJJ N7UJJ is offline
Teacher
AKA: Allan Cameron
FRC #5465 (BinaryBots)
N7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond repute
Re: Compressor fuse keeps blowing
Originally Posted by artdutra04 View Post
As the voltage of your main robot battery decreases, the amperage of the current traveling to all your electrical loads will increase. (E.g. Watts = Volts x Amps). This increased amperage is usually what blows the fuse on the Spike relay.
Replacing your main robot battery with a fresh one should take care of most of your issues.
Not correct. As the voltage of the battery drops, the current will drop also.
Ohm's law: current = voltage/resistance. As voltage decreases, current decreases proportionally. (half the voltage, half the current)
As voltage and current decrease, power (watts) decrease dramatically. Thus half the voltage, which results in half the current, means the power is one fourth of what it was.
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
Labview keeps freezing SHerpich LabView and Data Acquisition 31 02-02-2006 14:53
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
Time keeps on ticking /)/)/) archiver 2001 2 23-06-2002 22:12
Blowing 60 Amp fuse archiver 1999 4 23-06-2002 22:07
