Go to Post "No wheels, no problem, we can fix it in programming." - clean399 [more]
Unread 12-02-2007, 10:45
Rinaldi 427's Avatar
Rinaldi 427 Rinaldi 427 is offline
any help but programming
AKA: Angelo Rinaldi
FRC #1482 (the ghosts)
Rinaldi 427 is an unknown quantity at this point
pic: 1482 LIFTS TWO
Unread 12-02-2007, 10:46
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
Re: pic: 1482 LIFTS TWO
This is very impressive. Does this count as lifting all three robots?
Unread 12-02-2007, 10:47
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
No, it does not count as 3 because one is touching the ground...it is impossible engineering wise to do that now because of the rules. Looks good though, how much weight is on each side?
Min-Max to the Max!
Unread 12-02-2007, 10:54
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Doesn't that use a lot of air?
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 12-02-2007, 10:55
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Nothing is impossible. Many things are improbable. If you want to know how it is possible. Think about the ceiling...? Just a random thought that I thought worth posting. I am pretty sure there is some rule against this. But what if the a robot picked up the three opponents. It would make no strategic sense, but it would count as being possible.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 12-02-2007, 11:40
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Except for you the fact you are not allowed to react against field elements or ANYTHING outside the field.. This includes the ceiling. Its in the manual.
Regardless, that is a sweet bot.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 12-02-2007, 12:47
waiakea11's Avatar
waiakea11 waiakea11 is offline
FRC #1056
waiakea11 is on a distinguished road
fancy...
Unread 12-02-2007, 16:16
Charger_07 Charger_07 is offline
AKA: Escue
FRC #0932 (Circuit Chargers)
Charger_07 has a spectacular aura aboutCharger_07 has a spectacular aura about
how much weight is on each site
Chuck Norris likes to knit sweaters in his free time. And by "knit", I mean "kick", and by "sweaters", I mean "babies."
Nick: "I'm not Nick"
Unread 12-02-2007, 16:28
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Very impressive.
EDIT: Do you plan to protect the outer rams? They look like if a robot tried to get on and hit one it be broken fairly easily.
Eric Haskins KC9JVH
Unread 12-02-2007, 16:52
nsr's Avatar
nsr nsr is offline
nitroussuprarola
AKA: Ryan G.
FRC #2090 (P.E.T.T.)
nsr is on a distinguished road
Send a message via AIM to nsr Send a message via MSN to nsr
why not just lift the other two ramps instead of lifting your own robot too...that's going to requre alot of weight from the cylinders that you're going to need to lift the robots, and alot of pressure will be required too
Unread 12-02-2007, 17:27
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
lifting just the platforms presents some problems
Unread 12-02-2007, 17:35
triggerhappy336's Avatar
triggerhappy336 triggerhappy336 is offline
Driver
AKA: Craig Porter
FRC #2228 (CougarTech)
triggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of light
Send a message via AIM to triggerhappy336
It does, but we at 2228 think we have it down.
Now its just the whole, getting it to work part...
Unread 12-02-2007, 20:51
Andrew Blair's Avatar
FRC #0306 (CRT)
Are you running your compressor during the lift? Or will it lift the two robots, and your own, on the air in four tanks alone?
-Sir Francis Bacon
-Albert Einstein
Unread 13-02-2007, 16:22
AKA: Angelo Rinaldi
we know that ours don't count but we did it to avoid strengthining our drive system to hold 280 pounds. yes we are running our compressor we are protecting the rams and therei 140lbs on each wing we work on the kiss method yes we can lift off the floor if we dont desroy the carpet and it dose use a lot of air but it works
team 1482 proudly Canadian. proudly student built
TEAM 1482 LIFTS TWO Rinaldi 427 General Forum 13 13-02-2007 01:36
pic: Team 488 XBot two lifts getting closer Fred Sayre Extra Discussion 8 04-02-2007 16:58
1482 Help with Compressor Rinaldi 427 General Forum 7 31-01-2007 07:46
RINGERS 1482 Rinaldi 427 General Forum 0 25-01-2007 02:27
part shipment help 1482 ! Rinaldi 427 General Forum 0 25-01-2007 02:22
