Go to Post I am a FRC Coach/Mentor I don't know the meaning of the words "days off" or "rest". At least not from January to May. - Bob Steele [more]
Unread 12-02-2007, 11:11
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
Re: One Side Drives Faster than the Other.
sure you can create some crazy algorithm to get both motors output to be almost equal at any given rpm__ because the motor's difference between the motors changes with the rpm__ but that means that the robot will go slower that full capacity.
also the problem you have can be fixed by facing both motors the same direction then run a shaft paralel to one of the motors and have gears and chains reverse the rotation from clockwise to counter-clockwise
it's complicated maybe if i get the time ill take a pic of how we did it to show you; and this way you don't loose any speed
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 12-02-2007, 11:12
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
we had a similar problem and a victor was bad....use a multimeter to test the current on the victors in case something is bad
Unread 12-02-2007, 12:05
Originally Posted by Brandon Holley View Post
We took them out to mount em up, and I gave each motor shaft a quick twist. The 1st one was perfect, teh 2nd one, was horribly bound up. About half of the rotation was flawless, the other half required a bit of effort to turn. We figured we'd put it in the drive train to see if it would work itself out, but it appears that it may be getting worse. Any comments to this??
Brandon,
What you describe is usually the armature contacting the magnet structure. There are a variety of causes for this. The most common is dropping the motor which puts a small bend in the motor shaft or shifts the magnet structure a little. Check for obvious signs of external damage. Replacement is the only real fix on this. A good check is to power the motor up outside of your gearbox and then let it spin down by itself. If there is any rubbing of the internal structure it will be evident at this time with noise and intermittant braking.
Unread 12-02-2007, 12:19
Brandon Holley's Avatar
Thanks Al, I'll do that tonight and let you know how it works out.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
[wiki]: how to save more than one prog. in the RC Edourdo FIRSTwiki 1 04-02-2007 17:29
The American War on Science (FIRST is on the other side) JoelP General Forum 18 09-06-2006 14:47
Turning; easier one way or the other? FizMan Technical Discussion 14 03-07-2004 14:03
More than one joystick from one port Jmoo Programming 3 26-06-2003 18:01
How Do I Program My RC To Spot One wheel From Going faster than the other Kyle1010 Programming 5 12-01-2003 15:30
