Go to Post Without compromise, engineering would be boring. - Mike Betts [more]
Unread 12-02-2007, 06:41
RDD RDD is offline
RDD is an unknown quantity at this point
Switching to/from autonomous mode
HI EVeRYBODY!!!
ANSWER ME ON TWO QUESTIONS:
1)HOW I AM CHANGING TO AUTONOMOUS MODE WITHOUT CONFIGURING THE COMPETITON PORT AND ALSO WITHOUT USING A TETHER.
2)WHAT IS THIS ERROR:
"main.c' name exceeds file format maximum of 62 characters."
TNX FOR YOUR HELP!
Unread 12-02-2007, 07:32
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: HELP ME PLZ
1.) Did you set your team number in the OI?
2.) Your files are nested too deeply try moving them to c:\folder name
Unread 12-02-2007, 11:16
NeedMoreEngines's Avatar
NeedMoreEngines NeedMoreEngines is offline
AKA: Mike
FRC #1279 (Cold Fusion)
Team Role: Driver
NeedMoreEngines has a spectacular aura aboutNeedMoreEngines has a spectacular aura about
Send a message via AIM to NeedMoreEngines
Re: HELP ME PLZ
Originally Posted by RDD View Post
HI EVeRYBODY!!!
TNX FOR YOUR HELP!
1- well you're gonna wanna make an "Autonomous Switch" that allows you to switch between autonomous mode and R/C mode. I believe this plugs into the competition port. It's pretty easy you can buy all the stuff at radioshack.
2-Dunno. I'm not a programmer.
"There is only one solution to this problem- We need more engines."
The good thing about the YMCA is if you can spell, you can dance.
Proud Eagle Scout
Unread 12-02-2007, 11:22
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Re: HELP ME PLZ
HI EVeRYBODY!!!
TNX FOR YOUR HELP!
1. If you have a switch on your control system (or just one of the buttons on the joystick), you can have that execute your autonomous mode for testing. If you know how to, though, just do what NeedMoreEngines said and make yourself a switch.
For example, you can have something like
if(p1_sw_top == 1)
NameOfAutoMode();
2) See Kingof1337's post. He is right.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Unread 12-02-2007, 11:26
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
Re: HELP ME PLZ
im not in programing but the there is a switch that gets plugged into the OI called a dongle that allows you to toggle autonomus mode on or off.
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 12-02-2007, 12:35
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: HELP ME PLZ
1. Here is the schematic for the dongle. http://www.ifirobotics.com/docs/comp...guide-reva.pdf
2. The maximum length for the file names are 62 chars. Move your code to a short path(ie. C:\robots\2007\).
Eric Haskins KC9JVH
Unread 12-02-2007, 16:14
All I do is twin.
AKA: elixir
Re: HELP ME PLZ
In the long run, it will be beneficial to make one of these switches. You can use my suggestion above until you have something like this, but you do not and cannot use that during an actual competition.
Autonomous Switching Nicole_Ypes VEX 11 17-03-2007 08:09
Autonomous and user controlled mode switching sparrowkc Electrical 3 15-01-2007 13:15
Question about switching autonomous modes DemonYawgmoth Programming 2 23-03-2005 17:02
Receiving info from OI to select autonomous mode Mr. Lim Programming 21 17-02-2005 00:56
Switching the break mode archiver 2000 2 23-06-2002 23:28
