Go to Post Unfortunately, not everyone is Andy Baker. If everyone had this mindset, there would be far fewer problems. - Kevin Kolodziej [more]
Unread 12-02-2007, 13:53
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Camera Code Update
I've made a few changes to the camera code and would like to get some feedback before releasing it. If you can think of something you'd like changed or added, please leave a message here. These are the changes do far:
2/11/07 changes made for version 2.2:
Important: after loading the new software, make sure
you "Load default values" and then "Save changes" from
the tracking menu.
terminal.c/.h:
-Fixed benign bug where old_camera_t_packets was not getting updated in Tracking_Info_Terminal().
-Altered code to use Tracking_Config_Data values for center tilt and pan values instead of hardwired values in Tracking_Info_Terminal().
-Altered code to use Get_Camera_T_Packets() function instead of directly accessing camera_t_packets variable.
camera.c/.h:
-Added Poll_Mode() function.
-Added Get_Camera_ACKs() function.
-Added Get_Camera_NCKs() function.
-Added Get_Camera_T_Packets() function.
tracking.c/.h:
-Changed default CONFIDENCE_THRESHOLD_DEFAULT values to 10 (was 20).
-Greatly simplified search code (same functionality with less code).
-Changed search parameters so that a fixed tilt angle of about 30 degrees is used.
-For finer control, moved camera pan servo to PWM output 15.
-For finer control, Moved camera tilt servo to PWM output 16.
user_routines_fast.c:
-Replaced call to Generate_Pwms() in User_Autonomous_Code() with a call to PWM().
serial_ports_readme.txt:
-Corrected installation instruction #4.
camera_readme.txt:
-Added Virtual_Window() function description.
-Added Poll_Mode() function description.
-Added Get_Camera_ACKs() function description.
-Added Get_Camera_NCKs() function description.
-Added Get_Camera_T_Packets() function description.
pwm.h:
-Using new PWM() software, optimized camera tilt for a range of 0 to 90 degrees.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-02-2007, 14:04
Re: Camera Code Update
After I just finished porting your tracking software to work with WPILib...!!!!
Can't wait to test the new stuff out. I'm particularly excited about the increased servo resolution.
Unread 12-02-2007, 14:17
FRC #2429
This is the new search code:
// search code //
// To provide a delay for the camera to lock onto the
// target between position changes, we only step the camera
// to a new position every SEARCH_DELAY times while we're
// in search mode. SEARCH_DELAY is #define'd in tracking.h
loop_count++;
if(loop_count >= Tracking_Config_Data.Search_Delay)
// reset the loop counter
loop_count =0;
// If we're starting a new search, initialize the pan
// and tilt servos to the search starting point.
// Otherwise, just continue the search pattern from
// where we left off. The variable new_search is reset
// to one each time the tracking code (above) executes.
if(new_search ==1)
new_search =0;
temp_pan_servo = Tracking_Config_Data.Pan_Min_PWM;
temp_tilt_servo = Tracking_Config_Data.Tilt_Center_PWM;
else
// calculate new pan position based upon the current pan servo position
temp_pan_servo = (int)pan_servo_position;
// step the pan servo to its next destination
temp_pan_servo += (int)Tracking_Config_Data.Pan_Search_Step_Size;
// is the new pan servo position beyond the end of its travel?
if(temp_pan_servo > (int)Tracking_Config_Data.Pan_Max_PWM)
// send the pan servo back to the starting position
temp_pan_servo = (int)Tracking_Config_Data.Pan_Min_PWM;
// calculate new tilt position based upon the current pan servo position
temp_tilt_servo = (int)tilt_servo_position;
// step the tilt servo to its next destination
temp_tilt_servo += (int)Tracking_Config_Data.Tilt_Search_Step_Size;
// is the new tilt servo position beyond the end of its travel?
if(temp_tilt_servo > (int)Tracking_Config_Data.Tilt_Max_PWM)
// send the tilt servo back to the starting position
temp_tilt_servo = (int)Tracking_Config_Data.Tilt_Min_PWM;
// update the local variable used to store the current tilt servo positions
tilt_servo_position = (unsignedchar)temp_tilt_servo;
// update the local variable used to store the current pan servo positions
pan_servo_position = (unsignedchar)temp_pan_servo;
// update the pan and tilt servo PWM value
Set_Pan_Servo_Position(pan_servo_position);
Set_Tilt_Servo_Position(tilt_servo_position);
The increased servo resolution was mentioned towards the end of this thread:
http://www.chiefdelphi.com/forums/sh...ad.php?t=51802
-Kevin
Kevin Watson
http://kevin.org
Unread 12-02-2007, 14:25
team 2244 team 2244 is offline
Carla Sena
FRC #2244 (Free Access Evolution)
team 2244 will become famous soon enoughteam 2244 will become famous soon enough
Send a message via MSN to team 2244
Thanks for this new version!!!
Our team is having some problems with the CMUCam2.1 version, the tilt and pan is not moving and stuff like this!We`ll try to test this one.
Probably we`ll need to change the PWM`s to other outputs. Am I correct??(we`re newbies, and we need a lot of help!!!)
We hope it works!!!
Bye!
Unread 12-02-2007, 14:29
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Kevin's revised code takes advantage of the ability to use hardware built into the PIC to generate higher-precision PWM signals on PWM 13-16. This allows you finer control over the tilt and pan of the camera for better triangulation.
So, you could modify the code to use the PWMs you were before, but I would recommend moving to PWM 15 and 16 as Kevin has done.
Unread 12-02-2007, 14:37
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
Sounds excellent. I think you should release it as soon as possible; time is running short
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 12-02-2007, 14:40
Carla Sena
What you mean when you say better triangulation??
And where do I add this new search code that Kevin has created??
Probably I will do a lot of questions don`t be mad please
Thanks for your help!
Unread 12-02-2007, 15:54
If you don't already understand the innards of tracking.c, I think you're better off leaving it alone. The 2.1 code does exactly the same thing as this update, just not as elegantly.
Unread 12-02-2007, 16:08
Bharat Nain's Avatar
Request: Please release the streamlined version of this too.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 12-02-2007, 17:08
FRC #2429
Yes, once I'm reasonably happy with the code, I'll quickly port it over to the streamlined version. Unless I need to make some last minute changes, I'll zip-up the bells & whistles code tonight and post a link here.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-02-2007, 17:22
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Kevin, PWM outputs 15 and 16 are used for the (left?) motors. If you take those PWM outputs, we won't be able to use the camera to move the robot to the light. But of course, that's not a real issue, since I can change the Servo PWM outputs. But mabye others don't know how do to it and could freak out a bit because some of thier engines are not working.
I don't mind you have changed it, but just thinking about the weaker ones.
Our team will check the code tommorow, tweak it as needed.
Thanks for the update.
Unread 12-02-2007, 17:25
FRC #2429
I'm not sure the new code is elegant, but I am sure the old search code is not elegant .
-Kevin
Kevin Watson
http://kevin.org
Unread 12-02-2007, 17:33
FRC #2429
Yes, it's a pain, but I need to move the pan and tilt servos to the range 13 through 16 to exploit the new PWM() functionality. You make a good point and I'll make sure it's very clear in the readme_first.txt document that the assignments have changed.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-02-2007, 17:46
Bio's Avatar
Bio Bio is offline
AKA: Brian Dellon
None #1389 (Worst Case Scenario)
Bio is an unknown quantity at this point
Considering you've got a get, you may very well be including it already, but we would definitely appreciate Reset_Camera_ACKs() and Reset_Camera_NCKs() functions. Not a real big deal, but it would save us a variable.
Unread 12-02-2007, 19:48
Tyr333 Tyr333 is offline
FRC #1086 (Blue Cheese)
Tyr333 is an unknown quantity at this point
I've noticed that when the camera is in a search, if the camera is resetting its pan for a new sweep:
"if(temp_pan_servo >= PAN_MAX_PWM_DEFAULT)
temp_pan_servo = PAN_MIN_PWM_DEFAULT;"
and if the camera sees the light during this motion of resetting the pan to its minimum, when it arrives at this new pan position, the camera tilts down. It continues to search at this lower tilt, reaches the maximum pan, tilts back up, sweeps to its minimum pan, sees the light during this trip, and tilts down again. It continues this loop and never tracks the light. We don't usually have this problem, but at certain distances from the light it becomes impossible to track. What can we do to fix this?
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Problems when combine ADC code && camera code nirhaim1942 Programming 1 24-01-2007 06:58
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
