Go to Post We don't want "The Flame Heard 'Round the World"... - Andrew Blair [more]
Unread 12-02-2007, 17:24
robobrain0101's Avatar
robobrain0101 robobrain0101 is offline
FRC #1054 (The Knightmares)
robobrain0101 is an unknown quantity at this point
Send a message via AIM to robobrain0101
Victor Lights
I know I have seen this before but I cant remember exactl what it means though. The victor that is attached to our minibike motor is working at all, no matter what we do it just flashes orange. what do we do?
Unread 12-02-2007, 17:26
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
Re: Victor Lights
Check that the PWM cable is eeated correctly.
Also check the continuity of the pwm cable (we have found bad ones!).
The blinking light means the Victor is not getting a PWM signal.
Unread 12-02-2007, 21:31
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Re: Victor Lights
Check the PWM cables, 2 of the ones we got in the kit were no good.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 12-02-2007, 21:38
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
Re: Victor Lights
it probably not the cables guys. we had the same problem but i kept plugging it in until finally i happen to get it in correctly and it worked fine. Try plugging in the pwm cable at slightly tilted you will get it. We had this problem before and I was also able to help out another team with this problem with this solution. Chances are the problem doesnt lie in the cable or the pwm itself.
hopefully this helps
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
Unread 12-02-2007, 21:43
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: Victor Lights
Sometimes the pins on PWMs get bent or need to be bent to fit into the speed controller. I had this problem, but instead of un-routing all of my pretty electronics, I just bent the pins outward (think: shape of a "W" ) and it worked.
Unread 12-02-2007, 23:47
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
Re: Victor Lights
Flashing Orange means the Victor is not getting a PWM signal. And yes we had problems with bad cables also.
TEAM 1706
2007 Judges Award, St. Louis (For our amazing ability to have bad luck)
2005 Rookie Inspiration Award, St. Louis
Unread 13-02-2007, 07:37
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Re: Victor Lights
Because of the plastic shield around the PWM port on the Speed Controller it's kinda hard to see if you made a complete connection so try pulling the cable out and put it back and that should solve your problem. I doubt it's a defective cable but if you strongly think otherwise try another cable and see what happens. Usually though it's just seated correctly. I've had to reseat a PWM cable into the SC at least 5 times before I got it right. Try bending one pin slightly so that it can guide the rest of the pins into the port. Also make sure that you are not off a pin on the RC side as well - it's just as easy to miss a pin on the RC as it is a hole of the SC.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 13-02-2007, 11:26
Jeremytice's Avatar
Jeremytice Jeremytice is offline
Addicted to FIRST!
FRC #1126 (SparX)
Jeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to all
Send a message via AIM to Jeremytice
Re: Victor Lights
Yea we had the same problem with our cables in the first couple of weeks. The victors were blinking orange and we found out that 3 of our pwm cables were bad. We are just going to make our own pwm cables like last year. Since we have made them i dont think that we have had one problem with them.
2006 SparX FLR champions with 229 and 1567 after being seeded 1st and Radio shack innovation in controls at FLR
2006 Galileo Division-DIVISION CHAMPION (thanks to 177 and 201)
2006 BattleCry great alliance 1519 and 195.
2006 RCCR hometown champs with 378 and 2567
2007 FLR Innovation in Contols award
2007 Buckeye General Motors Industrial Design Award
2007 Buckeye Finalist with 1038 and 1528
2007 Galileo quarterfinalists with 229 and 191
2008 FLR finalists with 378 and 1551
2008 Buckeye Champs with 1024, 1386, and 2048
2008 Buckeye Motorola Quality Award
2008 IRI Finalists with 1024 , 1625, and 1731
Unread 13-02-2007, 12:42
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Victor Lights
Try making sure it's not the pwm port on the RC either. We had one victor that wasn't working; originally we thought it was the cable, but we switched with a working cable and it worked fine. So then we flipped a cable with a different victor, and huzzah!, the blinking victor worked.
But now the other one didn't.
To us it appears that PWM 2 on our RC isn't working correctly.
Unread 13-02-2007, 15:18
zako zako is offline
FRC #0481 (The HitchHikers)
Team Role: Electrical
zako is an unknown quantity at this point
Re: Victor Lights
It may be the code, If you are running more than 2 motors, i sugesst recoding.
My favorite tools...a bolt cutter, knife, hacksaw, drill...
Lights on Robot ptan Technical Discussion 6 11-01-2007 15:44
Lights? Total Meltdown Programming 2 17-01-2006 00:35
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
Spinny Lights archiver 2000 2 23-06-2002 23:48
Lights, Bumpers archiver 2000 15 23-06-2002 22:23
