Go to Post Never underestimate the ability of a team of high school students and engineers to break expensive things. - Alan Anderson [more]
Unread 12-02-2007, 17:47
Brigander's Avatar
Brigander Brigander is offline
Website Wizard
AKA: Andrew Roberge
FRC #1723 (F.B.I)
Brigander is an unknown quantity at this point
Solenoid Help
How do I Program A Soleniod to work with a vacuum system? I need to be able to control the vacuum system with a button on the joystick and have no clue to go about starting this process.
Only those who do not try are doomed to fail.
Unread 14-02-2007, 16:49
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: Solenoid Help
you need to open up user routines.c
and go down to where it maps the relays to the joystick buttons. and change what ever you need to change. if you want to use the triggers i think relay 1 and 2 are mapped in the default code already. hope this was helpful.
Unread 14-02-2007, 17:13
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Solenoid Help
Try easyC if you have a hard time programming with MPLAB. It will most likely make this much easier for you.
Help with the SMC SOlenoid FRC1710 Pneumatics 5 13-02-2007 13:22
Help with double solenoid almsfan21 Pneumatics 2 30-01-2007 19:57
Gunk in solenoid Nitroxextreme Pneumatics 3 22-02-2005 07:24
Double Solenoid Help doyler Programming 4 19-02-2005 11:36
24 Volt Solenoid? Stephen Kowski Pneumatics 2 27-01-2005 11:44
