Go to Post You could mount a small Black Hole on the top of your bot, and park it in front of the center goal - that would work...just keep your human player away from the event horizon. - KenWittlief [more]
Unread 12-02-2007, 16:40
KMAC42 KMAC42 is offline
KMAC706
FRC #0706
KMAC42 is an unknown quantity at this point
Globe Motors
Does anyone know if the globe motors from previous years are allowed on this year's robot??
Unread 12-02-2007, 17:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Globe Motors
If they are identical, yes, but not in a larger quantity than provided in the kit (one I believe).
Unread 12-02-2007, 17:31
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: Globe Motors
I think two comes in the kit.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 12-02-2007, 18:28
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Re: Globe Motors
Yes therre are 2 in a kit.
Oh and some advice. We've gotten in the habit of opening up the gearbox and adding some light grease to the transmission. We have had some in the past that came through with virtually no lubricant inside.
For the time it takes now it's much better than having a failure during a match.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Globe Motors Guy_E Motors 10 21-01-2007 16:53
globe motors arabsponsor Motors 16 29-01-2005 00:12
2 Globe Motors??? ChuckDickerson Motors 18 25-01-2005 15:53
Globe Motors? Brett W General Forum 3 10-01-2003 21:13
Globe Motors archiver 2000 1 24-06-2002 00:15
