Go to Post If we can transform our culture to the point where girls swoon over guys as they pull their dremel off their belt and carve some speed holes in a smooth fluid motion, I think FIRST is half way to its goal. When we get the guys to swoon over the girls for their hot moves on the 5-axis, we have won. - EricVanWyk [more]
Unread 12-02-2007, 19:14
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: camera goes to corner when finds light
Originally Posted by iiiii View Post
Using easy-c, I have a functioning camera code inside the operator control function. It looks left, right, up and down until it finds the light. When it does find it, the set servo tracking button usually will follow the light succesfully. About 30% of the time, however, once the camera finds the light, it just goes into the upper left corner, and I have no idea why. Does anyone know how to correct this?
If you are using the default tracking code, when it goes to the upper left, that means it has lost lock on the target and has restarted searching.
Are you using a fresh battery?
Camera finds overhead lights not green light theycallhimtom Programming 4 20-01-2007 17:37
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
pic: when prototyping goes wrong Whalley Extra Discussion 13 01-02-2006 21:31
Camera never finds target, stays at "Searching..." Mike Programming 12 22-01-2006 12:47
pic: When Good Metabolism Goes Bad. CD47-Bot Extra Discussion 24 17-05-2003 21:10
