Go to Post Sometimes the team really needs the kid, and sometimes the kid really needs the team. - Taylor [more]
Unread 12-02-2007, 20:08
trollin1st's Avatar
trollin1st trollin1st is offline
AKA: Janice Bourget
trollin1st is an unknown quantity at this point
Send a message via AIM to trollin1st
Disable After Autonomous
We were wondering if after the autonomous period if the robot is disabled or if it remains in autonomous and then proceedes directly into operator mode?
To err is human, and to blame it on the computer is more so.
Unread 12-02-2007, 20:30
half geek's Avatar
half geek half geek is offline
For an extremely large value of 1/2
AKA: Greg R
None #0294 (Beach Cities Robotics)
Team Role: Student
half geek will become famous soon enough
Send a message via AIM to half geek
Re: Disable After Autonomous
The short answer is I do not believe it will ever be disabled for a period after the autonomous period.
Edit: unless specifically disabled by the field operators.
In the default code, the robot is either in autonomous mode or not. Separately, the robot is either enabled or not.
In the following code segment from main(), the RC executes User_Autonomous_Code() if it is in autonomous_mode. User_Autonomous_Code() is a while loop, meaning the autonomous code and only the autonomous code will execute while (autonomous_mode). Immediately after leaving the autonomous while loop, main() calls Process_Data_From_Local_IO().
if (autonomous_mode)
        User_Autonomous_Code();
    Process_Data_From_Local_IO();
73 de W6DXN k
Parse this:
g r e g a ``n o s p a m" r o b i ``a t" d e v ``d o t" j a v a ``d o t" n e t
Unread 12-02-2007, 21:21
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
I'm 99% sure that the refs switch from autonomous straight to teleoperated without disabling first.
I'm not sure how the arena controllers perform this switch, though. (autonomous -> disable -> enable or autonomous -> enable)
Either way, if the robot is disabled between auto and tele, it will only be for a brief moment.
Unread 12-02-2007, 22:35
Andrew Blair's Avatar
FRC #0306 (CRT)
From my experience, in most cases where refs must count or otherwise need to reset something, all robots are disabled for a moment. Autonomous ends, all motion stops, there is a short pause, and then the cow-bell or whatever sounds, and it's time to go to work. And type run-on sentences.
-Sir Francis Bacon
-Albert Einstein
Unread 12-02-2007, 23:37
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
It depends on which perspective, from the softwares point of view, it does go straight from autonomous to teleoperated, however field control is more than likely going to disable the robot at least once between autonomous and teleop, there is actually a flag in the software, but it escapes my memory, so if you have something affected by an arbitrarily disabled robot controller you can have it check the flag every time around to make sure it waits for an enabled robot.
Matt Krass
Unread 13-02-2007, 10:38
<G14>...referees may validate placement of KEEPERS during the pause following the end of the AUTONOMOUS PERIOD.
Unread 13-02-2007, 14:21
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
Sorry I am new to this and have a few questions about autonomous mode as well...
How does the robot get into autonomous mode and how does it exit autonomous mode?
More importantly, how can I put our robot into autonomous mode to test the code that I have written for this?
Are we allowed to put our robots into a certain starting configuration by use of the joysticks or tethered mode before the start of the match and autonomous mode?
Due to lack of resources and the time crunch, we did not get our camera working and plan to just roll out of the end zone 10 feet and drop our keeper...
Any answers to the above questions would be very helpful!
Thanks
Unread 13-02-2007, 14:54
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
(A) How does the robot get into autonomous mode and how does it exit autonomous mode?
More importantly, (B) how can I put our robot into autonomous mode to test the code that I have written for this?
(C) Are we allowed to put our robots into a certain starting configuration by use of the joysticks or tethered mode before the start of the match and autonomous mode?
Thanks
I labeled the questions in the quote:
A. The field software controls whether your robot is disabled/in auto mode/operator mode. This is done by a cable you will plug into the competition port that is part of the field
B. To test auto mode you will want to make a dongle(switch) that plugs into the competition port. Information for the pin out can be found at: http://www.ifirobotics.com/docs/comp...guide-reva.pdf
C. You will have to bring your robot in your starting position by wagon/cart/dolly to the Queue line and then carry it by hand onto the field. . . So pretty much you can't tether up to your robot after you leave the pits except to possibly charge up your Pneumatics.
Japper I sent you a PM and E-mail with my contact information. . .
Contact me some how. . .
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Disable Encoders Problem mftaberner Programming 10 09-02-2007 23:26
Autonomous enable/disable Culvan Van Li VEX 4 21-09-2006 13:03
Bypass Disable Switch jakep Control System 36 19-08-2006 12:46
Camera does not search in autonomous mode after reset Keith Watson Programming 17 07-03-2006 00:42
Life After Dean: Who Will Lead FIRST After Kamen and Flowers?? Joe Matt General Forum 25 24-06-2002 00:12
