Go to Post As for Dave and the stairs, just ignore him like the rest of the FRC GDC does... ;) - Rich Kressly [more]
Unread 12-02-2007, 21:22
Ianuser Ianuser is offline
FRC #0570
Ianuser is an unknown quantity at this point
Re: Servo Values to Degrees... How?
This is what I have now, I have no idea if it is going to work. Please help if you can.
My tilt_servo is pwm07, my default MAX for tilt is 194, min is 94, center is 144, step is 50. QUESTION: if I change the step to 25, will it automatically make twice as many steps? will it cut the time in half? how is that programmed. ALSO, DOES THIS MAKE ANY SENSE????
const rom unsigned short targetRange[] =
    USHRT_MAX,  // zero index is undefined
5519,
2759,
1839,
1102,
918,
787,
688,
611,
549,
499,
457,
421,
390,
364,
340,
320,
302,
285,
270,
257,
234,
223,
214,
205,
197,
189,
182,
176,
169,
163,
158,
153,
148,
143,
139,
134,
130,
127,
123,
119,
116,
110,
107,
104,
101,
99,
96,
94,
91,
89,
87,
85,
82,
80,
78,
76,
75,
73,
71,
69,
68,
66,
64,
63,
61,
60,
58,
57,
55,
54,
53,
51,
50,
49,
48,
46,
45,
44,
43,
42,
40,
39,
38,
37,
36,
35,
34,
33,
32,
31,
30,
29,
28,
27,
26,
25,
24,
23,
22,
21,
20,
19,
18,
18,
17,
16,
15,
14,
13,
12,
11,
11,
10,
9,
8,
7,
6,
5,
5,
4,
3,
2,
1,
0
unsigned int Find_Distance(void)
	return(targetRange[pwm07-67]);
Those numbers in the array are the distance for each pwm index all the way up to 127 (90 degrees approximately). How does this relate to my 94 min, 194max for my tilt servo? Don't i have to change those to make this work? I'm a little confused. THanks!
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Servo Compact Design Problems!!! Dominator_Legen Electrical 22 07-04-2005 18:15
Servo Values DanDon Motors 8 14-02-2005 15:49
Dashboard View of Pan and Tilt Servo Values JoeXIII'007 Programming 1 02-02-2005 22:34
