Go to Post No need to apologize, you didn't do anything wrong. your just learning. thats what the forums are for. please keep them coming. - Tytus Gerrish [more]
Unread 12-02-2007, 22:52
Kapao69x5's Avatar
Kapao69x5 Kapao69x5 is offline
FRC Team 1872 Mentor
AKA: Jorge Valles
FRC #1872 (Yellow Fever)
Kapao69x5 is an unknown quantity at this point
Send a message via MSN to Kapao69x5
Question Power distribution block mounting
I would appreciate any sort of help at this point, since we are in the process of re-wiring our electrics.
How exactly do you mount the power distribution blocks on the DIN rails? I assumed since they came in the same bag in the kit of parts they have to to used in conjunction. (Even though my physics professor denies it. )
Also, following the 2007 power diagram, I noticed 3 of the four negative power blocks leading to a CIM motor (the kind we are using for driving), while the fourth one leads to to fuse box. My question is, do we need an extra negative power block or can we use a negative common and split one of the wires and use it on the fourth CIM. I find that solution very unprofessional but with the limited time frame until shipping the fifth block will have to wait.
Jorge Valles
Team 1872 - Yellow Fever
Mentor since 2008
San Juan, PR
Awards
Rookie Inspiration Award - 2006 UCF Regional
Unread 12-02-2007, 23:02
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Power distribution block mounting
There should be a screw on the top that lossens a clamp on each one that you can tighten to secure it to the rail. You can use any side to split the ground, so with one entry from the anderson connector you should have 7 to use however you wish, if you need more you'll need another block.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 12-02-2007, 23:04
Kapao69x5's Avatar
AKA: Jorge Valles
So we are supposed to use the holes in the rail to screw in the grey blocks?
Jorge Valles
Mentor since 2008
San Juan, PR
Awards
Unread 12-02-2007, 23:06
Imaginary Friend
AKA: Kevin Li
Team Role: Student
You use the holes on the rail to screw it onto your board, the blocks should have a screw that tightens or loosens a clamp that will secure the blocks onto the rail.
Kevin Li
596 - Sciclones
Unread 12-02-2007, 23:10
Kapao69x5's Avatar
AKA: Jorge Valles
Hmmm I'll have to look harder for that, I'll post a follow-up once I return to the shop. Thanks for the quick replies too.
Jorge Valles
Mentor since 2008
San Juan, PR
Awards
Unread 13-02-2007, 00:00
lancerbotics's Avatar
lancerbotics lancerbotics is offline
FRC #2250 (Lancerbotics)
lancerbotics is an unknown quantity at this point
Look at the following link to get the installation instructions for the power block.
http://www2.usfirst.org/2007comp_173...Strip%20R3.pdf
The red and black blocks just click on to the rail and the grey blocks have a screw in them to lock them to the rail.
Unread 13-02-2007, 07:30
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
For a quick and easy answer does the TERMINAL BLOCK have to be used? Is it a must or was it thrown in the KoP box to see how many teams would really use it - Much like the Camera which is optional.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 13-02-2007, 08:17
Kapao69x5's Avatar
AKA: Jorge Valles
It seems our DIN rail is too small, the anchors won't tighten on it. I'm almost sure that we have the same rails that came in the power block bag. I'm also pretty sure this is the only set of rails in the whole KoP.
Or am I missing something?
Jorge Valles
Mentor since 2008
San Juan, PR
Awards
Unread 13-02-2007, 08:32
OK,
Let's see if I can hit all the answers...
First, Yes, you must use the terminal block for power distribution. You can use only the number of blocks you need and leave the rest in you spares kit. The 40 amp returns (black wires) must come back to the black terminal block. The Electrical wiring diagram on the FIRST documents site will show you a typical robot wiring scheme. Modify it as you need for your robot design.
The link provided above also has a nice instruction sheet following the picture showing how to assemble the block. First slide a grey block onto the rail and tighten the locking screw until the block is held in place. Then assemble the other blocks as needed. The grey blocks do not have electrical connections they are made to lock the others in place. Please use the grey inserts to protect the exposed side of a terminal as shown in the diagram. According to a team update, you can cut the yellow jumpers if you use less then four of the blocks. The manufacturer recommends only one #6 wire be terminated on each side of the block, but you can terminate two #10 or smaller wires on each side.
The DIN rail should mounted on your robot before you mount the terminal block. You can cut the rail to just the size you need (the length of terminal blocks) and save some weight. We used steel rivets with washers to lock the rail in place on the robot.
Unread 15-02-2007, 00:17
nreyesciena's Avatar
nreyesciena nreyesciena is offline
Electrithingy
AKA: Nelson Reyes Ciena
nreyesciena is an unknown quantity at this point
Send a message via MSN to nreyesciena
We can use the amount we need and not all of the 4 block for each color? I think i saw someone mention that we need at least 3 of each, not sure where though. Anyways we know how to mount the DIN Rail, just not how to secure the blocks to the actual rail.
Would really help if we only had to install the amount we actually need and not all of them since all we need is 1 of each (1 circuit breaker panel), no 40 amp fuses.
EDIT: Not sure if the DIN Rail we have is the correct one, could you post a picture of the correct one to make sure?
"We have journeyed where none have been before. Now we return to ensure that none follow."
2006: Florida Event- Rookie Inspiration Award
2007: Boilermaker Regional and Buckeye Regional Events
Championship Event
2008: Florida Regional Event
Unread 15-02-2007, 07:32
Originally Posted by nreyesciena View Post
...Anyways we know how to mount the DIN Rail, just not how to secure the blocks to the actual rail....
lancerbotics already provided what you're asking for.
Unread 15-02-2007, 07:54
Nelson,
I would highly recommend you rethink your design. If you are using the AndyMark transmissions with the Chalupa motors (CIM) then you should use the 40 amp breakers and #10 wire for best results. These larger motors have a very high stall current and if you chose to run them on the 30 amp breakers you will find that they will trip and not give you the driving time you need. Please ask questions while you still have time before ship.
Unread 15-02-2007, 15:31
Kapao69x5's Avatar
AKA: Jorge Valles
Nelson,
On our driving tests we ran smoothly with 20 amp fuses on each motor. We upped it to 30 amp fuses to be on the safe side.
Our DIN rail's width is too small for the grey anchor blocks to latch on. We are not sure if we go the wrong size on the rails or they shipped us an incorrect type. It is the only thing missing on our electronics board so we can ship a running robot.
I will include a picture showing our grey anchor block on our DIN rail.
Thanks for the help in advance.
Jorge Valles
Mentor since 2008
San Juan, PR
Awards
Unread 15-02-2007, 15:34
jjdebner's Avatar
jjdebner jjdebner is offline
Jdizzle
AKA: Joshua Debner
None #0195 (Cyber Knights)
jjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud of
Send a message via AIM to jjdebner
Just a thought but maybe there is another DIN rail and the one that is smaller is the IGUS rail that comes in the kit?
- 2004 Entrepreneurship Award, UTC Regional
- 2004 3rd Place, NJ Regional
- 2004 J&J Sportmanship Award, NJ Regional
- 2006 Championship Finalist
- 2006 Innovation in Control Award, UTC Regional
- 2006 Championship Inovation in Control Award
- 2007 Winner UTC Regional
- 2007 GM Industrial Design Award, UTC Regional
Unread 15-02-2007, 15:52
Kapao69x5's Avatar
AKA: Jorge Valles
Igus bag came with aluminum rods and no rails. I remember checking out the DIN rails from the list coming from the block bag.
If there's any hope we could probably get some when we fly.
Jorge Valles
Mentor since 2008
San Juan, PR
Awards
Question:Power Distribution Block Pavan Dave Electrical 35 20-03-2007 20:10
Power Distribution Block Mounting Karma Electrical 5 23-01-2007 02:20
Power distribution Block? Pontchartrain Electrical 3 27-01-2006 07:30
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Power Distribution Block DukesElectrical General Forum 0 09-02-2004 23:48
