Go to Post The more rookies the better, they always think of the things that we dont - pakrat [more]
Unread 12-02-2007, 22:48
razor95kds's Avatar
razor95kds razor95kds is offline
razor95kds has a spectacular aura aboutrazor95kds has a spectacular aura aboutrazor95kds has a spectacular aura about
losing air pressure
this is the first time since our rookie year we are using pneumatics and we run into problems with losig air pressure in our system. We are planning to precharge our tanks and we assume that about 7-10 min will pass between when we charge the tanks and when the match will actually begin. However we lose about 30PSI in 10 min, leaving our systenm short on air. We are using pneumatics for 2 AM shifters and our tube gripper. All cylinders have small bore and throw, but we still thnk air shortage is a problem.
My question is anone else having leakage problems in their systems or do we need to reassembel are system with more teflon tape?
Unread 12-02-2007, 22:54
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: losing air pressure
You need to find where the leaks are via Leak detector(soapy water works) or by charging each section and plugging it, checking the pressure to see if there are any leaks. The fittings may either need to be tightened or retapped. I usually use on the the quick disconnect t connectors and connect two of the ends together to act as a plug if I need it.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 12-02-2007, 23:13
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Once you find the leaks using the soapy water method (and it works really well by the way), you'll need to take the joint apart and re-wrap the teflon tape. Not too much, make sure you go with the threads.
You'll get rid of the leaks in no time.
Good luck!
Brian Graham
Unread 13-02-2007, 07:17
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
take out each fitting, clean the threads (carefully) and wrap with one layer of teflon tape - make sure you don't cover the end - then re-install each fitting. use a wrench and make sure they are tight.
Also, be sure your tube ends are cut straight and pushed all of the way in.
With a tight system, you should be able to go for 30 minutes or more and only lose 5 -- 10 psi.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Pneumatics and air pressure Bomberofdoom Pneumatics 3 08-02-2007 22:30
pic: Losing stinks Joe_Widen Extra Discussion 1 27-05-2006 17:33
Will air pressure in venue affect path of ball? (was: DOES ANY ONE KNOW ????) RoboDriver Technical Discussion 5 17-01-2006 23:02
Are we allowed to use a Bimba air-to-air booster? Alex Minot Pneumatics 1 20-02-2005 22:32
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
