Go to Post Our team is using a video camera with frame-by-frame analysis to figure out all the characteristics of the foam ball. If the Boeing engineer says it's possible, I'm going to believe him. - sciencenerd [more]
Unread 13-02-2007, 09:54
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Important Q/A forum responses
Originally Posted by Dan Swando View Post
Even though the rule makes a lot of sense in the theory of "all power from the robot," logistically, it's a disaster. Hypothetically this means that you cannot use an offboard battery to power the compressor, even if you're using it at the competition. Why? Because the battery to power the compressor would count as a SECOND battery, and you're only allowed one battery to power your robot per match. Teams will HAVE to find a way to "port in" to their robot to power the compressor (like an electrical outlet). This is easily accomplished by having a couple of unused Anderson Connectors attached to the outside frame of your robot, connected to the rest of your wiring harness. Just plug, pressurize, and go!
I'm pretty sure an offboard compressor has always needed to be powered by an onboard robot battery. Atleast thats how I've always read the rule.
I'm much more concerned about the fact that ALL robot prep must happen with the competition battery. I understand the logic there, but keeping track of whether you're testing and debugging or actually resetting devices on your robot for a match will be a real nightmare. What if you've been debugging over lunch with a non-comp battery and parts of your robot end up in reset position and then you forget that you did so over lunch and don't re-reset them with a comp battery? I'm thinking that they'll almost have to be a bit lenient with this one and only come down on blatant repeat offenders. It's not as if you can scan the robot with a tricorder and find out if the quantum wave stat of the last electrons to course through it match a competition battery...
Unread 13-02-2007, 10:19
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
(Begin Sarcasm) Does this mean we have to use the battery to reset all stored power too, sine power is work over time and work is a change in energy. I mean so many teams are using gas springs, springs, latex tubing, gravity, etc. to activate mechanisms on their robot that they must clearly follow this poorly worded explanation by creating a Rube Goldberg powered off their battery to reset any and all mechanisms just to follow the rule because you know power is power and since it has to come from the battery all power on the robot must come from the battery. (End sarcasm)
The wording in that was poorly thought out but the intent is clear. They don't want you to use the old batteries in a way that may allow for them to get in the robot for competition. Don't lawyer like I did above and don't do something stupid like showing up to the field with an old battery on your robot or cart, and you'll probably be fine.
Pete
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 13-02-2007, 11:22
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by Peter Matteson View Post
... The wording in that was poorly thought out but the intent is clear. They don't want you to use the old batteries in a way that may allow for them to get in the robot for competition. Don't lawyer like I did above and don't do something stupid like showing up to the field with an old battery on your robot or cart, and you'll probably be fine.
Pete
Thanks for cutting to the chase, Pete. As you point out, the intent is clear. And competition officials will be looking for incorrect batteries in and around robots that are near the field. Inspectors will be looking at teams' pneumatics charging procedures in the pits.
Richard Wallace
since 2003
[Forum Help]: Forum tags Ken Leung CD Forum Support 8 17-01-2005 12:28
TechnoKats' designs - responses needed Andy Baker Chairman's Award 0 29-01-2003 09:52
Official Rule responses EStokely General Forum 4 11-01-2003 01:29
Strategic Responses Hubicki Rules/Strategy 16 22-01-2002 17:11
How important is it to register in this forum? Ken Leung General Forum 6 12-06-2001 21:14
