Go to Post Think, Write, Re-Think, Erase or Post - and Deal With it Either Way. - Chris Fultz [more]
  #31   Spotlight this post!
Unread 13-02-2007, 11:14
caraddicted101 caraddicted101 is offline
caraddicted101 has a spectacular aura aboutcaraddicted101 has a spectacular aura about
Re: Signal light trouble-shooting
Hey guys,
Team 668 has done all that and the light will not turn on. HOWEVER, I put the volt meter to pos. and neg. terminals on another light port on the RC when the robot was on and I tripped the light thus making it turn on. So, with this and in talking to our programmers i think that the lights will work just fine come competition. (They might need the competition controller to be plugged in to work)
Ryan Epperson
  #32   Spotlight this post!
Unread 16-02-2007, 21:27
MasterChief1732 MasterChief1732 is offline
MasterChief1732 is on a distinguished road
We just got our new relay today. So I put it on and nothing happened. There is a red light on the relay that lights up though. Is there a certain team color pin for the pwm cable to be connected too?
Thanks
  #33   Spotlight this post!
Unread 17-02-2007, 10:12
Master,
If the light on the relay is lighting then it is being fed correctly. The wiring error lies between the relay and the lamp. Be sure to install all the jumpers shown in the diagram particularly the one across the relay which supplies the return for the lamp.
  #34   Spotlight this post!
Unread 17-02-2007, 16:43
Team 1967 Team 1967 is offline
FRC #1967
Team 1967 is an unknown quantity at this point
We are having the same issue with our signal light, however, when in the voltage setting on our volt meter, we get an output of 12 for all of the connections on the signal light. Has anyone occured this problem before?
Green light same color as overhead light Ethulin Programming 13 02-08-2007 15:24
Whats the Robot Signal light for? steve d Electrical 12 20-02-2007 08:29
Multiple Light Tracking with Distinct Light Boxes MaHaGoN Programming 30 19-02-2007 10:46
Inventor software trouble/ FIRST Base trouble nasa-senpai General Forum 2 24-01-2007 09:15
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
