Go to Post Safety captains be watchful. - Al Skierkiewicz [more]
Unread 12-02-2007, 18:40
iiiii iiiii is offline
FRC #0637
iiiii is an unknown quantity at this point
camera goes to corner when finds light
Using easy-c, I have a functioning camera code inside the operator control function. It looks left, right, up and down until it finds the light. When it does find it, the set servo tracking button usually will follow the light succesfully. About 30% of the time, however, once the camera finds the light, it just goes into the upper left corner, and I have no idea why. Does anyone know how to correct this?
Unread 12-02-2007, 19:14
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: camera goes to corner when finds light
If you are using the default tracking code, when it goes to the upper left, that means it has lost lock on the target and has restarted searching.
Are you using a fresh battery?
Unread 12-02-2007, 19:16
FRC #0637
I am using a fresh battery, and I am not using the default camera code.
Unread 12-02-2007, 19:37
kaszeta's Avatar
Does it work with the default camera code, then?
Your code is controlling the servos, so if you aren't using the default code, you'll have to share at least some of your code with us.
Unread 13-02-2007, 11:16
jdejoannis jdejoannis is offline
FRC #1845
jdejoannis will become famous soon enoughjdejoannis will become famous soon enough
Is it locked on to the target though? Returning target data? If so, it may be a matter of the settings for the target pixel.
Unread 13-02-2007, 13:20
bcieslak
Posts: n/a
It sounds like youre camera looks away from the light.
In the tracking.h module there are some bits to change:
Look for:
// If your camera suddenly moves away from the target once
// it finds it, you'll need to change the sign on one or
// both of these values.
#define PAN_ROTATION_SIGN_DEFAULT -1
#define TILT_ROTATION_SIGN_DEFAULT +1
Try experimenting with these.
BC
Camera finds overhead lights not green light theycallhimtom Programming 4 20-01-2007 17:37
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
pic: when prototyping goes wrong Whalley Extra Discussion 13 01-02-2006 21:31
Camera never finds target, stays at "Searching..." Mike Programming 12 22-01-2006 12:47
pic: When Good Metabolism Goes Bad. CD47-Bot Extra Discussion 24 17-05-2003 21:10
