Go to Post The game ends after two minutes and fifteen seconds. The build season ends after six weeks. Using the experience to help improve yourself and the rest of the world will take the rest of your life. - dlavery [more]
Unread 05-02-2007, 18:01
FRC1710's Avatar
FRC1710 FRC1710 is offline
FRC #1710
FRC1710 is an unknown quantity at this point
Help with the SMC SOlenoid
Ok, So we read in the part description that when you charge both sides of the double solenoid it should hold position, however, this does not seem to be workin very well, we are looking over the schematics and the charts are not making sense does anyone know how to wire to up so we can have a forward, reverse, and a hold?
Unread 05-02-2007, 18:11
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Help with the SMC SOlenoid
From the 2007 Pneumatics Manual:
Always avoid turning on both solenoids at the same time. While this
won’t hurt the valve, you cannot be sure which way the spool will shift.
So, whatever you're doing, I would advise against charging both solenoids at the same time.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 05-02-2007, 18:16
FRC1710's Avatar
FRC #1710
OK, that is wrong, if that is the situation, then how are we supposed to stop a solenoid in Mid stroke which is what we need to accomplish because we are using a scissor lift...
Unread 05-02-2007, 18:29
The following thread should give you some ideas: http://www.chiefdelphi.com/forums/sh...ad.php?t=40040
Unread 05-02-2007, 21:55
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
The double solenoid that was shipped with the kit does not hold position. It either goes to one side or the other and when it does, the other side is exhausted to the atmostphere. You can make it hold by hooking up another solenoid to the exhaust and turning it on or off to make it hold. Another solution is to buy a valve that is "center off". It will hold position. See the other threads mentioned.
Brian
Brian K
Team 1225 Robotics Mentor
Unread 13-02-2007, 13:22
phittman phittman is offline
Mentor Extraordinaire
FRC #1652 (Lakeview Legends)
phittman is an unknown quantity at this point
Brian
There is a much easier way to do this instead of using a ton of solenoids and valves. SMC makes a valve that will allow you to stop anywhere within your stroke.
Help with double solenoid almsfan21 Pneumatics 2 30-01-2007 19:57
SMC Double Solenoid Screw Sscamatt Pneumatics 0 12-02-2005 01:24
Anyone willing to trade (something they need) for the SMC double solenoid? Jeremy Kit & Additional Hardware 0 27-01-2004 20:14
SMC Double Solenoid Valve Assembly Dave Kempskie Pneumatics 0 29-01-2003 13:34
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
