Go to Post if the school doesn't have a team - just start one. - Pattie [more]
Unread 10-02-2007, 18:24
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: Multiple Light Tracking with Distinct Light Boxes
Is that first@slashdot? Or is it correct as is?
Unread 10-02-2007, 20:01
tmbg37 tmbg37 is offline
AKA: Ted Kaplan
FRC #0694 (Stuypulse)
tmbg37 is an unknown quantity at this point
It is correct as it is, I'm not cool enough to have an email address at Slashdot
Team 694 - Stuypulse
http://www.stuypulse.com
Unread 10-02-2007, 23:29
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
In case you missed my post on your team's blog, Team 1648 would love to be able to have a copy of this code!
Thanks in advance,
Robinson Levin
me@robinsonlevin.com
Unread 13-02-2007, 14:08
Gaj Gaj is offline
FRC #0246
Gaj is an unknown quantity at this point
I would very much like to see this code -- the demo looked amazing!
(Email: hydrargyri@gmail.com)
Unread 15-02-2007, 11:53
Ankush Dhar Ankush Dhar is offline
FRC #2200
Ankush Dhar is an unknown quantity at this point
It seems you had talked about setting up a CVS respitory somewhere, but i cannot find it and wasn't able to get the copy of the code.
If you can, can you please provide me a copy of that code, thanks
killzone721@gmail.com
Regards
Ankush Dhar
Unread 15-02-2007, 14:15
lkdjm's Avatar
lkdjm lkdjm is offline
AKA: David Mazza
FRC #0564 (Digital Impact)
lkdjm will become famous soon enough
Send a message via AIM to lkdjm Send a message via Yahoo to lkdjm
I already have this code and I have played with it a lot. Now I am interested in using it practically. How do you actually "choose a light" to go to, and ignore the other. Also, when the camera sees 2 lights, it twitches back and forth between the two. Is there a fix for that? Also, if I want to go "in between" the 2 lights, how would I do that? With the twitching, it doesn't seem possible. Thank you in advance for your help.
Longwood's Digital Impact
Unread 15-02-2007, 15:36
FRC #2200
Ikdjm, Can u please, please send me that copy to my email! it will be awsome if you do so?
Regards
Ankush Dhar
Unread 17-02-2007, 08:17
Chuck Merja Chuck Merja is offline
Chuck Merja is an unknown quantity at this point
hey cool - and cool to you for sharing. we lost our programming mentor to a heavy work load, so we are trying to do autonomous in Easy C, but having trouble with the camera. Might you help us a bit? thnks team 1696 in the stix (Montana - not exactly the hotbed of C ) chuckm@3rivers.net and rcurtis3.3rivers.net
Unread 17-02-2007, 13:00
FRC #2200
Heh has anyone actally figured out how to pick the blob, either left or right?
other than that i wanted to ask one more quesion, i am not sure but anyone knows how to calculate the width of each blob?
please help if anyone knows
Regards
Ankush Dhar
Unread 17-02-2007, 21:05
AKA: Robinson Levin
The blob with the lower y coordinates will be closer (or the other way around if your camera is upside down). But you might consider going to the one that is more infront of your robot.
width = T_Packet_Data.x2 - T_Packet_Data.x1;
Good Luck,
Robinson Levin
Unread 17-02-2007, 21:47
MaHaGoN MaHaGoN is offline
MaHaGoN is a splendid one to beholdMaHaGoN is a splendid one to beholdMaHaGoN is a splendid one to beholdMaHaGoN is a splendid one to beholdMaHaGoN is a splendid one to beholdMaHaGoN is a splendid one to behold
I sent this e-mail out tonight to everyone that was on my mailing list.
Originally Posted by E-Mail
Dear Everyone,
Thank you for expressing your interest in this camera code. We have been happy to help those who have requested the code. As a result of snow delays and other complications, our team has changed directions and will no longer be pursuing the camera. As a result we can no longer continue developing the dual light code. If any of you are interested in still obtaining the beta code, I will be placing a link on the original Chief Delphi post shortly. It is stickied in the CMUcam sub-section of the Programming forum. Best of luck in their upcoming competitions, and we hope to see you at Nationals.
Thanks again, and good luck!
The Programmers of Team 250
Originally Posted by Prior E-mail
1. Please, please, please read the readme and check over the code before you run it on your robot. There's nothing out of the ordinary going on here, but we can not have foreseen your potential configuration, so please check over everything and make sure it's ok. (For example, pwm outputs are configured as in Mr. Watson's streamlined code, so there definitely is some (potential) non-neutral activity on every pwm. Please see user_routines.c if you need to comment this out.)
2. I should clarify that this code does not yet move the pan/tilt servos. We have started working on that but it's not yet debugged completely. Instead of waiting, I wanted to at least get this base code out.
3. If your camera is mounted upside down (see Kevin's post in the sticky on chiefdelphi) then the GUI representations will be upside down. I think everything else should work (I'm not totally sure of this).
I have attached a zip file with the uncompiled python scripts and the camera code for the robot. The executable python scripts were too large to attach. If you have any further questions I will try to get back to you.
Unread 17-02-2007, 23:23
AKA: Robinson Levin
Let us know if we can help with the situation, and thanks for posting it for all to enjoy.
Good luck,
Robinson Levin
Unread 18-02-2007, 11:12
neutrino15's Avatar
neutrino15 neutrino15 is offline
plɹoʍ ollǝɥ
AKA: Jordan Perr
neutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really nice
Question Re: Multiple Light Tracking with Distinct Light Boxes
Hello!
I am new to chiefdelphi and, well, new to FRC. Our team has been having trouble with the Virtual_Window command. Whenever we send the command, our camera seems to initialize. This makes the camera physically move back to it's starting position... We must be doing something wrong, we just don't know what. We came up with an alternate method of tracking the rack without using virtual window (only using a corner of the "blob" we see.) This solution is messy at best, so if anybody could help, please either reply or email me at neutrino15[at]gmail[dot]c0m. (the 0 is a o in com)..
Thank You!
-Jordan
Unread 18-02-2007, 13:43
AKA: Robinson Levin
We use this, it works quite well. Just aim to either corner (x1 or x2) instead of the center (mx).
Robinson Levin
Unread 18-02-2007, 22:45
Draggy Draggy is offline
AKA: Tiffany
FRC #1011 (CRUSH1011)
Draggy is an unknown quantity at this point
Send it to :
anriel.tuiqest@gmail.com
Please =)
Green light same color as overhead light Ethulin Programming 13 02-08-2007 15:24
Light Tracking theycallhimtom Programming 1 19-01-2007 15:11
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
Sensor Tracking the Boxes mjt902 Programming 25 29-01-2003 16:24
Please help me with the size of the rotating light!!! bigqueue Technical Discussion 5 21-01-2002 09:40
