Go to Post I'd rather have a bot in front of me than a frontal lobotomy. - Neal Probert [more]
Unread 13-02-2007, 14:21
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
Re: Disable After Autonomous
Sorry I am new to this and have a few questions about autonomous mode as well...
How does the robot get into autonomous mode and how does it exit autonomous mode?
More importantly, how can I put our robot into autonomous mode to test the code that I have written for this?
Are we allowed to put our robots into a certain starting configuration by use of the joysticks or tethered mode before the start of the match and autonomous mode?
Due to lack of resources and the time crunch, we did not get our camera working and plan to just roll out of the end zone 10 feet and drop our keeper...
Any answers to the above questions would be very helpful!
Thanks
Unread 13-02-2007, 14:54
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
(A) How does the robot get into autonomous mode and how does it exit autonomous mode?
More importantly, (B) how can I put our robot into autonomous mode to test the code that I have written for this?
(C) Are we allowed to put our robots into a certain starting configuration by use of the joysticks or tethered mode before the start of the match and autonomous mode?
Thanks
I labeled the questions in the quote:
A. The field software controls whether your robot is disabled/in auto mode/operator mode. This is done by a cable you will plug into the competition port that is part of the field
B. To test auto mode you will want to make a dongle(switch) that plugs into the competition port. Information for the pin out can be found at: http://www.ifirobotics.com/docs/comp...guide-reva.pdf
C. You will have to bring your robot in your starting position by wagon/cart/dolly to the Queue line and then carry it by hand onto the field. . . So pretty much you can't tether up to your robot after you leave the pits except to possibly charge up your Pneumatics.
Japper I sent you a PM and E-mail with my contact information. . .
Contact me some how. . .
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Disable Encoders Problem mftaberner Programming 10 09-02-2007 23:26
Autonomous enable/disable Culvan Van Li VEX 4 21-09-2006 13:03
Bypass Disable Switch jakep Control System 36 19-08-2006 12:46
Camera does not search in autonomous mode after reset Keith Watson Programming 17 07-03-2006 00:42
Life After Dean: Who Will Lead FIRST After Kamen and Flowers?? Joe Matt General Forum 25 24-06-2002 00:12
