Go to Post With FIRST, its all about style! In the northeast, we are alllll style. - Andy Grady [more]
Unread 13-02-2007, 15:58
Setsanto's Avatar
Setsanto Setsanto is offline
FRC #1334 (OTHS RobOTics)
Team Role: Animator
Setsanto is a jewel in the roughSetsanto is a jewel in the roughSetsanto is a jewel in the rough
Send a message via MSN to Setsanto
Mental ray and raytrace help
Could someone lease explain to me just where to find and how to use metal ray and raytrace. I'm a little confused as to their function.
2008 : GTA Regional 7th Seed, Quarters
2008 : Waterloo Regional 4th Seed, Quarters
2007 : GTA Regional 2nd Seed, Quarters
2007 : Waterloo Regional Quarters
Unread 13-02-2007, 16:04
FRC #0701 (RoboVikes)
Re: Mental ray and raytrace help
You should read the documentation, instructions on how to take full advantage of all of mental rays capabilities can't be explained in a post.
If you just want to use Mental ray instead of ScanLine just open the Rendering screen (F10)
then go to the bottom where there is a bar labled "Assign Renderer" click it and some more options will appear
There should be a lable that says Production and next to it will say "Default Scanline renderer" click the button to the right and choose mental ray.
this will turn on mental ray as your renderer, but in order to actually get good quality renders you need to take advantage of other things like GI ... which I could explain but It is all well documented so you should just read up on it.
Team 701
Unread 13-02-2007, 16:32
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Changing to Mental Ray or "mr" as you will see in some places will make more materials show up. Raytrace can be found in the material editor (press "M") Presets such as car paint, or some architectual stuff already has raytrace assigned to them so it dosnt take much tweaking. Raytrace makes things reflective.
Unread 13-02-2007, 17:21
Mazin Mazin is offline
FRC #1720
Mazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to all
Send a message via AIM to Mazin
Mental ray is a renderer. You know how when you render, you see that little white line move down the picture? That's the scanline renderer. Mental ray is a different renderer that has more features.
Raytrace is a rendering technique used to calculate reflections and refractions for things like glass and water. You can read up on this raytracing explanation (with awesome mspaint gfx!). Both the default Scanline renderer and mental ray can do raytracing.
Mental and physical aspects of Competition Swampdude General Forum 11 05-01-2005 12:54
Mental Ray Network Rendering Nero 3D Animation and Competition 5 28-01-2004 10:48
Some mental ray shaders Salik Syed 3D Animation and Competition 1 25-01-2004 19:57
Max6 + Mental Ray issues Efalunt 3D Animation and Competition 2 07-01-2004 21:05
Question on mental ray and 3dsmax6 licensing Nero 3D Animation and Competition 3 13-12-2003 22:29
