Go to Post Screws come even smaller, #0000 - 160 at Small Parts.They're about $4 each, and made by elves. - DonRotolo [more]
Unread 13-02-2007, 19:57
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Confusing Video
http://www.wolvcatrobotics.com/resou...0extension.MPG
take a look at this, i found this video, and was a bit confused on how this actually works.
its almost mind boggling to me.
anyone have any ideas?
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 13-02-2007, 20:12
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Re: Confusing Video
Its a cascade style lift, just with the chains/belts ran internally. Its actually much like what our team is doing this year for a lift - it makes the sections extend simultaneously. This helps make it smooth with an equal motor load throughout extension, and also helps stability - as you have greater overlap across multiple extensions until you near your limit.
Check out slide 17 on this powerpoint from the workshops at championships last year - it shows the cascade and continuous systems drawn out side-by-side. http://www.usfirst.org/uploadedFiles...ors_Needel.ppt
Unread 13-02-2007, 21:01
Bochek's Avatar
AKA: Adam Bochek
Re: Confusing Video
so it is a cascading style arm then, but how do they run the cables on the inside?
Unread 13-02-2007, 21:17
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: Confusing Video
lots skill and pulleys/idlers/sprokets.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 13-02-2007, 22:17
Ricky2443's Avatar
Ricky2443 Ricky2443 is offline
FRC #1029
Ricky2443 is on a distinguished road
Re: Confusing Video
yea actually theres 2 hamsters inside and when connect to power we shock them and that pushes it up...other than its complicated we dont expect u guys to understand lol
Ricky D.
Webmaster..."no Web GURU i like the sound of that"
Unread 13-02-2007, 22:32
Keo-san's Avatar
Keo-san Keo-san is offline
AKA: Victor Marmol
FRC #1029 (WolvCats)
Team Role: Driver
Keo-san is an unknown quantity at this point
Re: Confusing Video
We ahev worked our buts off in this tower! Its the first year we implement it. It has no idles gears. It has sprocket and chain but its a rather innovative design.I've seen other towers and our works a little different. We'll post more pictures later. Ohhh wanna know how we got rid of idler gears?? search for our tensioner pictures those are cool!
Team 1029
CMU '11
Unread 13-02-2007, 23:02
Bochek's Avatar
AKA: Adam Bochek
Re: Confusing Video
that is wicked cool, im still confused on how it goes back in so well.
Unread 13-02-2007, 23:23
Rich Ross Rich Ross is offline
Let's get Desperate!!!
AKA: 830 Alumni
FRC #1504 (The Desperate Penguins)
Rich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond repute
Send a message via AIM to Rich Ross
Re: Confusing Video
going back in is a process aided mainly by gravity. The weight (not mass) of the arm pulls it back down in, so that when you loosen the chains/pulleys, the arm slides itself back down. After having used a similar design in 2004 (having a 15 foot tall arm) I'd say this is a strong option. It's a fairly easy design to make, and easy to maintain (ours never broke, only bent in one place that was weakened for other functionality purposes.
Unread 13-02-2007, 23:39
Keo-san's Avatar
AKA: Victor Marmol
Team Role: Driver
Re: Confusing Video
Our 2005 arm was aided back down by gravity and because of that it proved painfully slow. It was 9ft. high and took about 4-5 seconds either way. This one is 8.5 feet high and it goes up or down in less than two second regardless of its aid by gravity. We didn't want gravity to be the driving force for lowering the tower and we came up with the mechanism you see to power the tower both up and down efficiently and quickly.
Team 1029
CMU '11
Unread 13-02-2007, 23:45
efoote868 efoote868 is online now
foote stepped in
AKA: E. Foote
FRC #0868
Re: Confusing Video
looks really nice, hopefully it weighs very little, and the rest of your robot works just as well! Can't wait to see video of you guys competing!
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 13-02-2007, 23:52
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
Re: Confusing Video
it weighs 15lbs including the claw that is not in the video clip
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
Unread 14-02-2007, 11:34
Chris155hp's Avatar
Chris155hp Chris155hp is offline
Chris155hp is an unknown quantity at this point
Send a message via AIM to Chris155hp
Re: Confusing Video
It took 4 ever to make
Unread 14-02-2007, 11:47
11Mort11's Avatar
11Mort11 11Mort11 is offline
AKA: Alex Joss
FRC #0011 (MORT)
11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold11Mort11 is a splendid one to behold
Send a message via AIM to 11Mort11
Re: Confusing Video
We are using somthing like this as our end effector/arm
80/20 lift
Unread 14-02-2007, 13:36
Swan217's Avatar
Swan217 Swan217 is offline
RoboShow Producer
AKA: DJ Royal Fusion
no team (RoboShow)
Swan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond repute
Send a message via AIM to Swan217
Re: Confusing Video
I have to give you major props for this design. The ThunderChickens (217) tried a similar design back in 2004 and we had a heckuva time with cables binding inside our extendo-arm. It was really hard to troubleshoot too since all of the components were enclosed in the arm.
Our 2004 robot can be seen here.
Orlando Regional Planning Committee & Cohost of The RoboShow & RoboVision
Follow The RoboShow on Twitter @RoboShowLive & check out our website, www.theroboshow.net
Follow RoboVision on Twitter @RoboVisionOD & check out our website, www.robovisionod.com
"As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything."
— President Barack Obama
Video: Cyber Blue 234 Late Night Programming Video JAH Robot Showcase 6 13-03-2005 00:34
Confusing Shipping date, NYC regional Denman Rules/Strategy 1 02-02-2005 11:14
Confusing Compiler Error UrsaMNet Programming 2 28-10-2004 14:32
One Confusing Math Problem Bharat Nain Math and Science 4 01-02-2004 17:21
Ahh! Program trick confusing! archiver 2001 9 24-06-2002 02:26
