Go to Post I suggest that you don't discuss...sensitive issues about your team on this public forum. - Andy Baker [more]
Unread 14-02-2007, 10:27
RDD RDD is offline
RDD is an unknown quantity at this point
Exclamation SOS
HI EVERYBODY!!!!
we have connected the camera correctly and when we downloaded the kevin's program " Version 2.1 of the "bells and whistles"to the RC. it wrote in the terminal window" camera not detected" or something like that. it is the first time we try to use this code. we connected the rc to oi by radio . i also have changed in the file "tracking.h" the pwms and also copied our Default_Routine in user_routines.c.
what we did wrong??
or what we have to change to make the camera work?
tnx for your help!!!
Unread 14-02-2007, 10:36
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: SOS
I'm gussing your changes to the code haven't messed up the camera because its printing camera not found. I'm guessing you have the PAN, Tilt, TTL serial port, and power attached securely to the camera. And I hope you have the the power switch on the camera to the 'on' position. Make sure your backup battery is charged. (The backup battery runs the camera). Double check those and see if it still doesn't work.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 14-02-2007, 10:56
RDD RDD is offline
Re: SOS
I Want to ask you what I have exactly to change to make the robot moves towards the green light except the tracking pwms and why wheN I am moving the joysticks nothing happens with the kevin's code ??
Unread 14-02-2007, 12:24
Bharat Nain's Avatar
Re: SOS
Many things:
First off, visit www.kevin.org/frc/camera
Most of your questions will be answered there.
Default_Routine which consists of all the joysticks mappings have been disabled for safety reasons. Search around the forum more for more answers.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
