Go to Post edit: laptop. yeah as a programmer to not put this in I should be taken out the back and "decompiled". - Stuart [more]
Unread 14-02-2007, 10:28
RDD RDD is offline
RDD is an unknown quantity at this point
Question help me plz
HI EVERYBODY!!!!
we have connected the camera correctly and when we downloaded the kevin's program " Version 2.1 of the "bells and whistles"to the RC. it wrote in the terminal window" camera not detected" or something like that. it is the first time we try to use this code. we connected the rc to oi by radio . i also have changed in the file "tracking.h" the pwms and also copied our Default_Routine in user_routines.c.
what we did wrong??
or what we have to change to make the camera work?
tnx for your help!!!
Unread 14-02-2007, 10:32
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: help me plz
How did you connect it?
Are you sure the camera is getting power? Are the little LEDs lighting up?
Unread 14-02-2007, 10:40
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: help me plz
Hmm..why did you double post?
Anyway my response is on your other thread:
http://www.chiefdelphi.com/forums/sh...&highlight=SOS
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 14-02-2007, 10:48
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Re: help me plz
Check your TTL and connections.
Unread 14-02-2007, 10:53
RDD RDD is offline
Re: help me plz
yes I will check the TTL but also I Want to ask you what I have exactly to change to make the robot moves towards the green light except the tracking pwms and why wheN I am moving the joysticks nothing happens with kevin's code ??
Unread 14-02-2007, 13:23
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Re: help me plz
Well let's see, first, Kevin's code does not call the ifirobotics routine, Default_Routine, in which the joystick to chassis pwm connection is made. He only wants to demo the camera capabilities and not let your 'bot run wild
To track the light, we decided to let the driver have a switch (the trigger on our single joystick) when he (or she) holds it, he has control of the y or forward motion. We use the camera servo position data, so nicely packaged by Kevin, and a PID control function to control the x or side-side motion. I'll leave the details of that to you
Don't PANIC!
S. P. A. M.
Unread 14-02-2007, 13:25
Re: help me plz
You claim that your camera is connected properly, but the error message says it's not. Does the camera have power? The green light should be on. Is it getting data? The red light should flicker slightly.
We can't tell you what "exactly to change", because we don't know anything about your robot. It also isn't fair -- either to us or to you -- for us to do your work for you.
The reason none of the joysticks do anything in Kevin's camera code is because he has disabled the call to Default_Routine(). That's the function in the default code which copies joystick values to motor outputs. It conflicts with the servo tracking outputs, so before you put it back in, you'll have to change it to match how your robot is wired and avoid setting the camera servo pwm outputs.
program camera w/o RC? (was: PLZ HELP!!!) RDD Programming 2 31-01-2007 14:30
Aim high poster help plz? Clam Website Design/Showcase 3 07-02-2006 21:26
Missing Item plz help! Cory Chit-Chat 12 06-05-2003 00:39
Plz help with codec Chris Nowak 3D Animation and Competition 7 18-02-2003 16:15
HELP W/ CONVERTING FILES PLZ... Matt Attallah Chit-Chat 3 03-01-2002 18:47
