Go to Post Physical items will be lost along the way eventually but memories will never be forgotten. - Connor McBride [more]
Unread 14-02-2007, 08:56
DustinB_3 DustinB_3 is offline
FRC #0935 (Railerobotics)
DustinB_3 is an unknown quantity at this point
Signal Light
We've mounted the light and wired it to the relay but it doesn't work. Is it only supposed to work during competition? I am positive I wired it correctly. I check it 5 times. Could the relay have burned up? Any help is appreciated.
Unread 14-02-2007, 09:52
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Re: Signal Light
Hi Dustin, If you wired the light according to the diagram on page 38 of the tips and good practices you need to check the 2007 Robot Signal Wiring Diagram. The wiring diagram has an additional jumper wire from 1 to 4 on the relay socket that the good practices one doesn't show. Also some teams got the wrong solid state relay in their KOP. Make sure you have 700-SK0C2Z25 which is a DC relay.
Unread 14-02-2007, 11:28
Re: Signal Light
Is the signal light supposed to do anything more than be on when the main battery is supplying power, and off when it is not?
Unread 14-02-2007, 11:30
Re: Signal Light
I have wired it according to the 2007 Robot Signal wiring diagram. The wrong relay could be the issue. I'll check the part number immediately after school. If the relay is the wrong one how would I go about getting the correct one.
Unread 14-02-2007, 11:39
jts jts is offline
FRC #0900
jts is on a distinguished road
Send a message via AIM to jts
Re: Signal Light
Update #9 addresses this issue and gives you information on obtaining the correct relay.
Unread 14-02-2007, 13:35
Re: Signal Light
Using version 13 of the main code, our signal light blinks when the robot is enabled and is on steady when the robot is disabled. I didn't notice anything different in behaviour between teleoperated mode and autonomous.
(We plugged in one of last year's team color lights just to see what it did. It alternated blinking red and blue, and I think the red signal is what drives the relay.)
Unread 15-02-2007, 08:44
Re: Signal Light
Dustin,
I know that this is hard to see in the diagram in the Tips and Guidelines, but you need to add a jumper between terminals 1 and 4 on the relay for the light to turn on.
Unread 15-02-2007, 10:04
Re: Signal Light
Actually I check the part number on the relay and we got the wrong one. I have emailed FRCParts but they haven't gotten back to me yet. I have doubled check my wiring and I do have a black jumper wire between 1 and 4.
Unread 15-02-2007, 10:29
Re: Signal Light
Getting the right relay should clear things up. Let us know.
Unread 21-02-2007, 11:56
lancerbotics's Avatar
lancerbotics lancerbotics is offline
FRC #2250 (Lancerbotics)
lancerbotics is an unknown quantity at this point
Re: Signal Light
We had the wrong relay too and one of my mentors was able to work it out so that the light worked even with the wrong relay I will send him this thread and see if he can't tell you how he solved the problem.
Unread 21-02-2007, 13:10
Re: Signal Light
I am guessing he wired it direct to the team color output.
Green light same color as overhead light Ethulin Programming 13 02-08-2007 15:24
Whats the Robot Signal light for? steve d Electrical 12 20-02-2007 08:29
Multiple Light Tracking with Distinct Light Boxes MaHaGoN Programming 30 19-02-2007 10:46
Signal light trouble-shooting customh Electrical 33 17-02-2007 16:43
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
