Go to Post An opportunity is always there waiting to be discovered, we just have to look and then see what we can do to help create change. - JaneYoung [more]
Unread 14-02-2007, 13:06
Ianuser Ianuser is offline
FRC #0570
Ianuser is an unknown quantity at this point
Re: Where do I begin to get the robot to move using the camera?
Thanks. I made these changes, hopefully it will work:
At the top of user_Routines.c I declared this
int pwm03_On_Off = 1;
Then in the Default_Routine() where I map to the joysticks I put this
if(pwm03_On_Off == 1)
	pwm03 = p3_y; //ForkLift
An example of my switch-case statements (for a metal sensor that increments the 'count' variable each time it passes...and there each time it passes certain things happen in the CASE...) is this
if((pwm03 < 125) || (pwm03 > 129))  //if py_3 is being used (forklift going up or down)
		if((now == 1) && (last == 0)) //If sensor, which connects to Dig In/Out port 4, sends a signal...
			count++; //Number of times tape passes through the sensor.
			Switch1_LED = 1; //Switch01 goes on when the tape passes the sensor.
		else
			Switch1_LED = 0;
		switch(count) //for sensor module
			case 1:			//if count = 1 then that just means that it passed through the first piece of tape which will be used to show that it is in full DOWN position.
				Relay2_green = 1;
				Relay2_red = 0;
				printf("count = 1");
				break;
			case 2:
				Relay2_green = 1;
				Relay2_red = 0;
				pwm03 != p3_y;
				pwm03_On_Off = 0;
				pwm03 = 127; //Motor stops when it reaches 1st level of rack.
				printf("count = 2");
				break;
There are more cases, but those are the basic formats of the others anyway. Basically for case 2: I want to have he motor pwm03 stop and the joystick not mapped to pwm03 anymore. I have this in my code that allows me to reset the counter and to remap pwm03 to the joystick (so we can move it again):
This is all still in Default_Routine()
             last = now;
	now = rc_dig_in04;
	last2 = now2;
	now2 = p3_sw_trig;
	last3 = now3;
	now3 = p3_sw_aux1;
//some other stuff, but then:
if((now3 == 1) && (last3 == 0)) //p3_sw_aux1 sets counter to 0 in case forklift needs to be reset.
		count = 0;
	if((now2 == 1) && (last2 == 0)) //p3_sw_trig sets joystick 3 y-axis to forklift motor. Use after each level.
		pwm03_On_Off = 1;
So, think this will work? there is a snowday at my school today and they wont let us in to work on the robot, so I have to wait another day before I can test any of this. Thanks
Unread 14-02-2007, 19:54
jdejoannis jdejoannis is offline
FRC #1845
jdejoannis will become famous soon enoughjdejoannis will become famous soon enough
That won't work because the next time around the fork lift is going to be reconnected to the joystick.
This does not do what you think it does:
pwm03 != p1_y;
Lets say p1_y is equal to 200 at the moment, so we have
pwm03 != 200;
Which means pwm03 is going to be set to 0 (for the moment). You will need an if or switch statement for your joystick.
Also you might want to put a \r\n in your print statements. Keep up the good work!!
Jason
Unread 16-02-2007, 17:55
FRC #0570
Please help me, I can't figure out how to use the camera to actually MOVE the robot. I have the camera code working along with the camera itself, but how do I move pwm01 (left drive wheel) and pwm02 (right drive wheel) individually according to the pan of the camera? I have no idea where to begin with this code. (I just got the code to work for the camera and I've been trying for weeks. Now I only have 2 days, Please help if you can)
int I_Want_To_Search = 1;
int pwm01_On_Off = 1;
int pwm02_On_Off = 1;
int pwm03_On_Off = 1; //these are all at the top of user_routines.c Everything else is in Processfrom master UP (except TARGETRANGE[] and FIND_DISTANCE())
                          if(I_Want_To_Search == 1)
		Servo_Track();
                          if((Get_Tracking_State() == CAMERA_ON_TARGET) || (Get_Tracking_State() == TARGET_IN_VIEW))
			pwm01_On_Off = 0;
			pwm02_On_Off = 0;
			pwm01 = 230; //Desired Forward Velocity
			pwm02 = 230;
			Switch3_LED = 1;
			//printf("2"); //these statements are just to see if it worked
		else
			Switch3_LED = 0;
			pwm01_On_Off = 1;
			pwm02_On_Off = 1;
			//printf("4"); //these statements are just to see if it worked
		if(Find_Distance() <= 50) //THIS DOESN"T WORK!! WHY NOT?
			pwm01 = 127;
			pwm02 = 127;
			pwm01_On_Off = 1;
			pwm02_On_Off = 1;
			I_Want_To_Search = 0; //Stops calling Servo_Track(). THEN CALL ANOTHER THING
			Switch3_LED = 0;
			//printf("3"); //these statements are just to see if it worked
		if(p1_y > 129 || p2_y > 129)
			pwm01_On_Off = 1;
			pwm02_On_Off = 1;
		else if(p1_y < 125 || p2_y < 125)
			pwm01_On_Off = 1;
			pwm02_On_Off = 1;
The Find_Distance() function is this:
unsigned int Find_Distance(void)
	return(targetRange[pwm07-144]);
and target range is this:
const rom unsigned int targetRange[] =
3355,
1676,
1116,
835,
666,
553,
472,
411,
363,
325, //place 10
293,
267,
244,
225,
208,
193,
179,
167,
156,
146, //place 20
137,
128,
121,
113,
107,
100,
94,
89,
83,
78, //place 30
73,
68,
64,
60,
56,
51,
48,
44,
40,
36, //place 40
33,
29,
26,
23,
19,
16,
13,
10,
6,
3, //place 50
0, //place 51
So I would like to know why my distance thing isn't working (Max tilt is 194 and min is 94, center at 144. My degree per pwm step was 1.7647 (50/90? is that right?) Then I multiplied that by the pwm index up to 51 and found the radian value and plugged it into TAN(x) and then did 116-12.625(my height)/tan(the radian value from before)) Assuming that's correct, what's wrong with the rest of the code? It's not working properly. Camera looks away from the light when I comment in the Find_Distance code (less than 50 or whatever). ALSO, how do I program the robot to move forward???
Building the field :: where can I get the carpet? Armando Gonzalez Technical Discussion 10 12-01-2007 14:14
Where in the world is the new 2007 cmu camera docs?!?!? xrabohrok Programming 13 08-01-2007 20:28
Where do we get more extention wires for the Vex robot? pbrules15 Technical Discussion 5 27-01-2006 07:48
how do u figure out the torque req'd to move a robot? Salik Syed Technical Discussion 11 03-11-2004 08:12
Using Robotics to get the girl necroprime Chit-Chat 66 21-03-2003 23:21
