Re: Bumper crisis...kinda
I don't know, that's why I am asking lol
I don't think they would be THAT picky, but I'd just pick up some 3/4" plywood just in case.
It would be much more effective and you would not have to worry about the judges not allowing it
Thanks guyz
I will go buy plywood now! |
First off, inspectors aren't going to see it. They will only see the back of one sheet of plywood - because your material is covering all other parts.
And what is plywood, except glued together thinner sheets? I can't see any reason we can't make our own plywood out of other materials, even if that material is two thinner sheets of plywood. Now, whether it is wise to use it or not - That depends on how you are fastening your material around the wood. Are you using angle aluminium screwed into the wood? If so, are you screwing into the ends of the wood? You may want to have commercially glued 3/4" plywood rather than relying on your own glue. I guess the real question is why you want to bother? Just go buy a sheet or half-sheet of plywood. |
are you tight on money or what?
#7
Hell no! We have plenty
#8
oohh stupid...just buy new plywood....it will be quick.....
#9
Thanks. But we don't do things the easy way, we do it as complicated as we can, so we can be screwed in the end.
Not to mention the plywood is damaged... Last edited by Hiromi : 14-02-2007 at 14:19. |
#10
gluing them together would damage the integrity of the bumper and it would probably break halfway through the competition
#11
true that. I will try to get more plywood....>.>
#12
Is the plywood you are gluing damaged? Is that why you are gluing it?
if so, just get new plywood ![]() |
#13
The answer to your question is
GET NEW PLYWOOD |
| Peace Corp kinda things? | Mike | Chit-Chat | 8 | 21-05-2006 21:41 |
| Hotel Room Crisis For Atlanta | Nawaid Ladak | Championship Event | 19 | 25-04-2006 12:30 |
| Compression Crisis | reisser | 3D Animation and Competition | 9 | 22-02-2004 11:23 |
| pic: lego Planitary... Kinda | CD47-Bot | Extra Discussion | 5 | 14-07-2003 23:55 |
| WHAT kinda Computer? | Gun | 3D Animation and Competition | 9 | 24-02-2003 00:19 |
