Go to Post Just so you don't spend too much time on non-clues ... now you can all go back to the real one! :D - Libby K [more]
Unread 14-02-2007, 13:23
Hiromi's Avatar
Hiromi Hiromi is offline
AKA: Angela Watson
FRC #1752 (TeamTonkaRobotics)
Hiromi will become famous soon enoughHiromi will become famous soon enough
Send a message via Yahoo to Hiromi
Exclamation Bumper crisis...kinda
For the standard bumpers, the plywood has to be 3/4 in. thick. Can we take two pieces of 3/8 in. plywood and glue them together, and it still be considered standard bumpers?
Unread 14-02-2007, 13:44
fastmustang67 fastmustang67 is offline
fastmustang67 is an unknown quantity at this point
Re: Bumper crisis...kinda
no i don't think you can
also, it would not be exactly 3/4in
just go get 3/4in plywood at a store
it would save you a lot of time and energy of gluing and waiting for the glue to dry
Unread 14-02-2007, 13:46
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Are the refs going to be that picky? Would they seriously disallow 3/8" plywood, or call it 'custom' even though everything else is the same?
Hi!
Unread 14-02-2007, 13:47
Hiromi's Avatar
AKA: Angela Watson
I don't know, that's why I am asking lol
Unread 14-02-2007, 13:48
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
I don't think they would be THAT picky, but I'd just pick up some 3/4" plywood just in case.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 14-02-2007, 13:53
It would be much more effective and you would not have to worry about the judges not allowing it
Unread 14-02-2007, 13:56
Hiromi's Avatar
AKA: Angela Watson
Thanks guyz
I will go buy plywood now!
Safety third!!
No adult work without student supervision!
You know you have been with FIRST too long when at RadioShack you know more than the employees do about Vex.
Unread 14-02-2007, 14:02
GaryVoshol's Avatar
Cogito ergo arbitro
First off, inspectors aren't going to see it. They will only see the back of one sheet of plywood - because your material is covering all other parts.
And what is plywood, except glued together thinner sheets? I can't see any reason we can't make our own plywood out of other materials, even if that material is two thinner sheets of plywood.
Now, whether it is wise to use it or not - That depends on how you are fastening your material around the wood. Are you using angle aluminium screwed into the wood? If so, are you screwing into the ends of the wood? You may want to have commercially glued 3/4" plywood rather than relying on your own glue.
I guess the real question is why you want to bother? Just go buy a sheet or half-sheet of plywood.
(since 2004)
Unread 14-02-2007, 14:04
are you tight on money or what?
Unread 14-02-2007, 14:06
Hiromi's Avatar
AKA: Angela Watson
Hell no! We have plenty
Safety third!!
Unread 14-02-2007, 14:07
oohh stupid...just buy new plywood....it will be quick.....
Unread 14-02-2007, 14:08
Hiromi's Avatar
AKA: Angela Watson
Thanks. But we don't do things the easy way, we do it as complicated as we can, so we can be screwed in the end.
Not to mention the plywood is damaged...
Safety third!!
Unread 14-02-2007, 14:09
gluing them together would damage the integrity of the bumper and it would probably break halfway through the competition
Unread 14-02-2007, 14:10
Hiromi's Avatar
AKA: Angela Watson
true that. I will try to get more plywood....>.>
Safety third!!
Unread 14-02-2007, 14:18
Thumbs down Re: Bumper crisis...kinda
Is the plywood you are gluing damaged? Is that why you are gluing it?
if so, just get new plywood
Peace Corp kinda things? Mike Chit-Chat 8 21-05-2006 21:41
Hotel Room Crisis For Atlanta Nawaid Ladak Championship Event 19 25-04-2006 12:30
Compression Crisis reisser 3D Animation and Competition 9 22-02-2004 11:23
pic: lego Planitary... Kinda CD47-Bot Extra Discussion 5 14-07-2003 23:55
WHAT kinda Computer? Gun 3D Animation and Competition 9 24-02-2003 00:19
