Go to Post A good driver will always win over a good robot. - Mike Norton [more]
Unread 14-02-2007, 14:57
RyanW RyanW is offline
FRC #0449 (Blair Robot Project)
RyanW has a spectacular aura aboutRyanW has a spectacular aura about
Encoder Counting Problems
In order to keep track of the height of our manipulator, my team is using a BaneBots 36mm Gearbox Mount encoder attached to their 64:1, 36mm Planetary Gearmotor, RS-540 Motor. As we move the manipulator up, the encoder starts to count up, but then quickly goes down. Moving the manipulator down makes the encoder count down more slowly.
I have tried the encoder with two sets of code - the interrupts from the Quadratuer Encoders white paper and Kevin's encoder code. In both cases, I am having the same problem. I am getting the encoder values by printing out the number every 26 loops.
Does anyone know what might be wrong with the encoder?
Unread 14-02-2007, 15:17
Re: Encoder Counting Problems
did you calibrate the encoder per the directions?
Problems with Encoder Counting bjimster1 Programming 19 07-03-2007 09:59
Encoder Problems bjimster1 Programming 2 10-02-2007 08:04
Encoder counting randomly off by x4 factor jgeorge Programming 5 02-02-2006 21:17
Problems counting encoder pulses bludstayne Programming 7 02-02-2004 23:07
