Go to Post We fail to present a coherent picture of what we are if we aren't vigilant about our self-image. - Alan Anderson [more]
Unread 14-02-2007, 14:40
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
HELP: analog input
Hey,
I'm trying to get an analog input from my 10 Kohm but all i get is a series of numbers counting downwards and reseting the controller makes it go back from the number in which it stopped instead of the one in which it began...
Any suggestions?
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 14-02-2007, 14:58
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
Re: HELP: analog input
Originally Posted by Tottanka View Post
Hey,
Any suggestions?
If you could post the relevant portion of your source code here, we could offer you some insight.
Otherwise, the best we could offer up is a generic "look at Kevin's code" here: http://www.kevin.org/frc/ response.
--Dave
Unread 14-02-2007, 15:08
Tottanka's Avatar
AKA: Liron Gurvitz
printf("Pot %d\r", Get_ADC_Result(1));
Unread 14-02-2007, 15:17
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
The counting occurs when nothing is connected.
Make sure that the Pot is plugged into the right pin.
In Kevin's ADC, #1 is actually analog in #2 (#0 is pin #1).
Unread 14-02-2007, 15:44
Tottanka's Avatar
AKA: Liron Gurvitz
we did what you said but it still counts.
can any body please send us a working code for the potentiometer using the analog inputs.
Unread 14-02-2007, 16:03
Bharat Nain's Avatar
Without using Kevin's code:
Potentiometervalue = Get_Analog_Value(rc_ana_in01);
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 14-02-2007, 16:52
Kevin Watson's Avatar
La Caņada High School
FRC #2429
I think Bharat is trying to tell you (and he's right) that it's overkill to use my code to read a potentiometer. Just use his example and it should work. If you really want to use my code, if I remember correctly, Get_ADC_Result() returns an unsigned int, which means you should use %u in your printf() format string, not %d.
-Kevin
Kevin Watson
http://kevin.org
Unread 15-02-2007, 09:22
Tottanka's Avatar
AKA: Liron Gurvitz
We have tried both things, with Kevin's code and it still did not work...
any further suggestions?
Unread 15-02-2007, 09:50
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Is your potentiometer wired correctly? Red and black to the outer leads, white (signal) to the center? The problem you described only occurs when nothing is plugged in, so make sure you're referencing the correct analog input in your code, that the pot is wired correctly, and that it's not broken (which is kind of hard to do.. test another one?).
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 15-02-2007, 09:55
Tottanka's Avatar
AKA: Liron Gurvitz
We tested it with a voltmeter and it all good....
Unread 15-02-2007, 10:19
But is it wired up correctly? You can test it at a point on the potentiometer and get correct readings. However, if it is not wired up correctly, the processor will not be able to read it. There is also a slight chance the processor itself has corrupted analog pins. That happen to our 2006 controller at the end of the season.
-= Bharat Nain =-
Unread 15-02-2007, 10:38
Tottanka's Avatar
AKA: Liron Gurvitz
the potentiometers are good like i said...
We have checked it with a voltmeter connecting between the where the white cable connects and where the red one connects and it shows the correct results.
We have also tried to change the ports, and neither of them worked...
Unread 15-02-2007, 11:24
If your idea of "good" does not match what the RC expects, it won't work no matter how many times you check to see that it's "good". In order to help you, we need to know exactly how you have wired it. Answering "we wired it correctly" is not going to help. For example:
But where did you connect the black wire? What measurement are you making, and what results are you getting? Answering "the correct results" does not help.
A potentiometer on the Robot Controller's analog inputs needs three wires. Black (ground) goes to one end of the pot. Red (+5) goes to the other end of the pot. White (signal) goes to the wiper.
Unread 15-02-2007, 11:48
Tottanka's Avatar
AKA: Liron Gurvitz
Like i said before...its connected CORRECTLY...
There is another problem...
Black goes to left side of potentiometer
Red goes to its right leg
and white goes to the middle one...
and they connect to the analog inputs correctly
We have measured voltages between red and white legs, and it shows inputs from 0 to 4.95V liniarically to the rotation i make...
Here's our code:
printf("%u",Get_Analog_Value(rc_ana_in01));
does not work with %d or %u....
could you show me the code of Get_Analog_value...perhaps the problem we have has to with that function...
Unread 15-02-2007, 12:46
buddy.smith buddy.smith is offline
Master Control
FRC #1795
buddy.smith is an unknown quantity at this point
I don't know this first hand, but does the analog port need to be setup as an input somewhere? Does the ADC need to be enabled?
ttyl,
--buddy
FRC analog input RC filter values Gdeaver Control System 2 01-01-2006 22:03
Analog and digital input question Robby Control System 7 30-04-2005 20:07
Analog Input Trouble Matt Krass Programming 10 20-01-2005 21:09
Resistance to Analog Input Value. Josh Hambright Electrical 12 15-04-2003 16:12
DC Motor current to an Analog Input junkyarddawg Motors 43 04-04-2002 15:53
