Go to Post FIRST will work with you if you work with them. - R.C. [more]
Unread 14-02-2007, 17:28
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Re: help!!!
Globes must be on a VICTOR. We had thought you could run it on a spike, however in the manual it states that it needs to be on a VICTOR. The Globe however, does not need a 40 amp circuit and is allowed to run off a 30 amp breaker from the fuse panel. A good place to check these are in the Tips and Good Practices Page and 2007 Power Distribution page on USFirst.
The Mabuchi can be either of the two. If it's a low torque situation and the motor won't draw much current then use a spike, but if your using it in a high torque situation like in a drive or an arm, then I suggest using a Victor on a 30 amp circuit
what gearmotor do you refer to? Is it the new Keyang Window Motor?
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Help: How do we get a teacher to help? (was: Help) ChaosAlchimey General Forum 13 21-01-2007 11:57
