Go to Post If you don't have a hairtie, use a ziptie instead. It works, it's cute, and way geeky. :p - Katie Reynolds [more]
Unread 14-02-2007, 19:37
LieAfterLie's Avatar
LieAfterLie LieAfterLie is offline
FRC #2028
LieAfterLie is an unknown quantity at this point
Joystick Input calibration in software
We've found a working serial joystick with 4 analog axes, but the problem is it's not calibrated, and there are no calibration wheels on the stick. It's meant to be calibrated by a driver of some sort. My question is is there a way to manually set the voltage range to map the 0-254 input to?
SEMPER UBI SUB UBI
Unread 14-02-2007, 19:52
Re: Joystick Input calibration in software
If I understand what you want, the code that Dave Flowerday posted in this thread should help: http://www.chiefdelphi.com/forums/sh...ad.php?t=53527
Unread 14-02-2007, 20:16
FRC #2028
I could do that, but then I would lose everything outside of the joystick's current range. It's centered at 69, it's maximum is 245, so 0 includes a huge range at the bottom. 0 includes what should be 0 - 107 (245-69-69), so I need to change both the center voltage and the mV per input tick. All of the 4 axes are off by alot.
SEMPER UBI SUB UBI
Unread 14-02-2007, 21:44
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
try opening the joystick and seeing if the pots are adjustable
/forest
issues limiting a joystick input Unholy Programming 7 12-02-2006 19:53
Gyro Calibration ImmortalAres Programming 1 07-06-2005 13:29
Calibration/Zeroing of Joystick archimedes Programming 3 21-02-2005 19:10
Calibration of CmuCam xxmaddjxx Technical Discussion 1 09-01-2005 18:39
2.5 is alive !!!! (input ! .. more input ! ) Lloyd Burns Programming 2 14-01-2003 19:15
