Go to Post Maybe my brain fog factor has expanded after wading through 1114's competition data sheet, so I cannot see the forest for the trees. - Bill_B [more]
Unread 14-02-2007, 19:54
jdejoannis jdejoannis is offline
FRC #1845
jdejoannis will become famous soon enoughjdejoannis will become famous soon enough
Re: Where do I begin to get the robot to move using the camera?
That won't work because the next time around the fork lift is going to be reconnected to the joystick.
This does not do what you think it does:
pwm03 != p1_y;
Lets say p1_y is equal to 200 at the moment, so we have
pwm03 != 200;
Which means pwm03 is going to be set to 0 (for the moment). You will need an if or switch statement for your joystick.
Also you might want to put a \r\n in your print statements. Keep up the good work!!
Jason
Unread 16-02-2007, 17:55
Ianuser Ianuser is offline
FRC #0570
Ianuser is an unknown quantity at this point
Please help me, I can't figure out how to use the camera to actually MOVE the robot. I have the camera code working along with the camera itself, but how do I move pwm01 (left drive wheel) and pwm02 (right drive wheel) individually according to the pan of the camera? I have no idea where to begin with this code. (I just got the code to work for the camera and I've been trying for weeks. Now I only have 2 days, Please help if you can)
int I_Want_To_Search = 1;
int pwm01_On_Off = 1;
int pwm02_On_Off = 1;
int pwm03_On_Off = 1; //these are all at the top of user_routines.c Everything else is in Processfrom master UP (except TARGETRANGE[] and FIND_DISTANCE())
                          if(I_Want_To_Search == 1)
		Servo_Track();
                          if((Get_Tracking_State() == CAMERA_ON_TARGET) || (Get_Tracking_State() == TARGET_IN_VIEW))
			pwm01_On_Off = 0;
			pwm02_On_Off = 0;
			pwm01 = 230; //Desired Forward Velocity
			pwm02 = 230;
			Switch3_LED = 1;
			//printf("2"); //these statements are just to see if it worked
		else
			Switch3_LED = 0;
			pwm01_On_Off = 1;
			pwm02_On_Off = 1;
			//printf("4"); //these statements are just to see if it worked
		if(Find_Distance() <= 50) //THIS DOESN"T WORK!! WHY NOT?
			pwm01 = 127;
			pwm02 = 127;
			pwm01_On_Off = 1;
			pwm02_On_Off = 1;
			I_Want_To_Search = 0; //Stops calling Servo_Track(). THEN CALL ANOTHER THING
			Switch3_LED = 0;
			//printf("3"); //these statements are just to see if it worked
		if(p1_y > 129 || p2_y > 129)
			pwm01_On_Off = 1;
			pwm02_On_Off = 1;
		else if(p1_y < 125 || p2_y < 125)
			pwm01_On_Off = 1;
			pwm02_On_Off = 1;
The Find_Distance() function is this:
unsigned int Find_Distance(void)
	return(targetRange[pwm07-144]);
and target range is this:
const rom unsigned int targetRange[] =
3355,
1676,
1116,
835,
666,
553,
472,
411,
363,
325, //place 10
293,
267,
244,
225,
208,
193,
179,
167,
156,
146, //place 20
137,
128,
121,
113,
107,
100,
94,
89,
83,
78, //place 30
73,
68,
64,
60,
56,
51,
48,
44,
40,
36, //place 40
33,
29,
26,
23,
19,
16,
13,
10,
6,
3, //place 50
0, //place 51
So I would like to know why my distance thing isn't working (Max tilt is 194 and min is 94, center at 144. My degree per pwm step was 1.7647 (50/90? is that right?) Then I multiplied that by the pwm index up to 51 and found the radian value and plugged it into TAN(x) and then did 116-12.625(my height)/tan(the radian value from before)) Assuming that's correct, what's wrong with the rest of the code? It's not working properly. Camera looks away from the light when I comment in the Find_Distance code (less than 50 or whatever). ALSO, how do I program the robot to move forward???
Building the field :: where can I get the carpet? Armando Gonzalez Technical Discussion 10 12-01-2007 14:14
Where in the world is the new 2007 cmu camera docs?!?!? xrabohrok Programming 13 08-01-2007 20:28
Where do we get more extention wires for the Vex robot? pbrules15 Technical Discussion 5 27-01-2006 07:48
how do u figure out the torque req'd to move a robot? Salik Syed Technical Discussion 11 03-11-2004 08:12
Using Robotics to get the girl necroprime Chit-Chat 66 21-03-2003 23:21
