#9
Re: Robot won't go straight
(A) IF spinning: Reverse the polarity on one motor. Remember that one runs forward and one runs backwards on a standard outward facing differential drive, so one will have the red lead on the Victor's M+, whereas the other will have the black lead on it (and vice versa for the M- connection). (B) IF arcing in a gentle "S" curve (arc one way forward, the other backward): You have "motor timing" issues, where the motor favors one direction over the other. Others have posted that the CIMs are not SUPPOSED to be "timed" (favor one direction), but in reality they always seem to favor one way or the other slightly. This can be compensated for via several methods: a power factor lookup table to balance the power to each side based on command, closed loop steering control with the gyro (slave one motor's speed to the other via integrating the gyro data - see the Whitepapers or kevin.org for more information), mechanical coupling of the two sides (tough to do without designing a clutch), or a different drivetrain geometry, like skid steer 4WD or 6WD (also tough to change now, since we're in week six!) (C) If it is favoring the SAME side both forward and backward: You either have one motor more powerful than the other (CIM output is rated +/- 10 percent per copy), or the drivetrain is BINDING more on one side than the other. Check for binding first. That is the most common reason when this occurs. Check for: binding in the CIM-Transmission coupling (VERY common source!), for misalignment in gear and/or sprocket-chain sets, binding wheel bearings, and if live shafts are used, defective/dry pillow blocks or a misaligned/bent shaft. Also be sure that the far end of the motor/gearbox shaft is supported with a pillow block! If it's not, chain tension can bind up a gearbox. If you suspect motor-to-motor variance, try a different combination of CIMs. (D) It COULD be a programming problem, but that's unlikely. You can easily disprove ANY variance in the control system & programming is responsible, by simply switching which side each Victor controls (IOW, swap motor wiring to the Victors, keeping everything else identical). This is an easy test to do. If the symptom shifts sides, then you actually have a programming or electrical problem! If not, then it's a motor, transmission, drivetrain, wheel, or other mechanical problem. I hope this helps you diagnose your problem. - Keith McClary Chief Engineer, Team 1502 "Technical Difficulties" |
| Robot Technology We Won't See In FIRST | petek | Math and Science | 0 | 08-05-2006 08:40 |
| Robot doesn't drive straight | bush | Control System | 14 | 09-02-2006 00:00 |
| Speed controllers won't communicate w/robot controller | steven114 | Control System | 12 | 03-02-2005 21:26 |
| Speed controllers won't communicate w/robot controller | steven114 | Electrical | 12 | 03-02-2005 21:26 |
| Shipped straight to Florida.... | archiver | 2001 | 3 | 24-06-2002 01:54 |
