Go to Post Remember that though we come from different backgrounds and x, y, z, we are all on each other's side. We want people to love STEM, and think FIRST is a great tool to fulfill that desire. - PayneTrain [more]
Unread 14-02-2007, 20:09
brennerator brennerator is offline
brennerator is an unknown quantity at this point
RAndom C++ Problem
#include <iostream>
using namespace std;
int main()
int a,b,c,d;
b=0;
c=1;
d=1;
cout << "Which Fib do you want to find?";
cin >> a;
do
cout << c << endl;
c = c + d;
cout << d << endl;
d = c + d;
b++;
while (b<a)
cout << "And those are the fibs" << endl;
Any help?
Unread 14-02-2007, 21:28
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: RAndom C++ Problem
I'm not sure what this segment is supposed to do; a quick look at the source didn't reveal much (maybe I'm just being dense, but I didn't get it), but it won't even compile without a semicolon ( at the end of the while.
Here's the output from the test run I gave it:
Which Fib do you want to find?5
5
8
13
21
34
55
Good luck with this and post back if you need help,
JBot
Aren't signatures a bit outdated?
Unread 14-02-2007, 22:45
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by brennerator View Post
#include <iostream>
int main()
int a,b,c,d;
b=0;
c=1;
d=1;
cin >> a;
do
cout << c << endl;
c = c + d;
cout << d << endl;
d = c + d;
b++;
while (b<a)
Any help?
Help with what? It looks like a Fibonacci number generator.
-Kevin
Kevin Watson
http://kevin.org
Unread 14-02-2007, 23:35
How can you make the user enter in one of the numbers in the sequence and have hte prog spit it out
Unread 14-02-2007, 23:37
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Just run a test before the number is outputted. If the number is < the inputted number, continue, if number == the inputted number, end with result, if number > inputted number, return error to user.
Unread 15-02-2007, 13:49
FRC #0701 (RoboVikes)
int fib(int number)
if(number==0 || number ==1) return number;
else return fib(number-1)+fib(number-2);
yay.
User enters a term, it spits out the fib value for that term.
Look at the inductive definition of Fibonacci series if you want to see why this works
It runs in N*N time though.There are alot of clever optimizations that can be done to make this faster.
Team 701
Unread 15-02-2007, 13:55
Oops, i didn't even see the code you had so far... well I think what you are doing works fine, just follow the advice above.
Team 701
Unread 15-02-2007, 14:14
FIRST JerseyKid's Avatar
FIRST JerseyKid FIRST JerseyKid is offline
Alumni
AKA: Erik Cokeley
FRC #0025 (Team Mercury)
FIRST JerseyKid is on a distinguished road
Send a message via AIM to FIRST JerseyKid Send a message via Yahoo to FIRST JerseyKid
i think u need a ; after the while
Team 1089 alumni coach.
Unread 15-02-2007, 15:04
Cheezmeister Cheezmeister is offline
FRC #0871
Cheezmeister is an unknown quantity at this point
Yep, that's right.
Random Stuff Brm789 Chit-Chat 11 20-11-2003 16:13
Random Thought... Marygrace Chit-Chat 12 14-05-2003 15:50
How random is random???? archiver 1999 0 23-06-2002 21:59
Random Marc P. Chit-Chat 138 13-02-2002 15:11
Random Question... Jessica Boucher Chit-Chat 26 02-07-2001 21:37
