Go to Post Students, mentors, schools, corporations, teams, and communities - they are all critical to the success of FIRST. . - dlavery [more]
Unread 14-02-2007, 21:06
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
How does Your ramp/lift work?
I was making a polished animation of our ramp and how it works for display at regionals, when I realized that maybe we were unique with the way we did the lifting. I'm just wondering how your team's ramp/lift works.
Our robot is a "teeter-totter" on wheels. We use the weight of one robot to offset the weight of another, so that when we do have to actively lift another 'bot, we'll only have to lift 10-15lbd of their weight... which is easily done with a single pneumatic piston. We should only have to actively lift someone when the weight difference is very high between the robots, and the lighter one gets on first; which we will try to avoid through strategy at the beginning of the match.
Here's the (almost) final pit animation.
Unread 14-02-2007, 21:51
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: How does Your ramp/lift work?
Nice animation, it gets the idea across very clearly so people should have no problem understanding the design. I think I can honestly say that's the one lift idea I've seen posted that we didn't think of.
Only questions are do you have hard stop for the first robot so they don't drive off or go too far before the second bot? Do you have a reset for when some one drives too far if you don't have a hard stop?
I know I didn't answer the question.
Good luck in Philly this year we won't make to defend the title with you.
Pete
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 14-02-2007, 21:59
triggerhappy336's Avatar
triggerhappy336 triggerhappy336 is offline
Driver
AKA: Craig Porter
FRC #2228 (CougarTech)
triggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of light
Send a message via AIM to triggerhappy336
Ours drops the ramps on each side, then 3 11 stroke pistons on each side lift the ramps. The ramps drop and rise in a way that doesn't require either of the other bots weight on our robot. So we can lift only one if one bot dies, or two if they both make it back.
Unread 14-02-2007, 22:01
Andrew Blair's Avatar
FRC #0306 (CRT)
Pete
We do have a hard stop. If you drive too far, you simply drive backwards till the thing flips down again. However, in certain cases of driving too far, no amount of mechanism will recover that...;-)
As for our title... None of us will be there I guess! CIA and ourselves will be attending Cleveland instead. Good luck up north!
-Sir Francis Bacon
-Albert Einstein
Does your brain work? Beth Sweet Chit-Chat 23 13-06-2006 22:27
How does your auto-aim work? JamesBrown Programming 36 28-03-2006 23:25
How does it work? Ryan O Control System 5 12-03-2006 19:15
How does Nationals work? coldfusion1279 Championship Event 29 30-03-2005 16:47
How Does a Winch Work? Aaron Lussier Technical Discussion 23 20-01-2004 21:14
