Go to Post It's a club if you have a bunch of people who hang out and do nothing - It's a team if all you all work together and cooperate to win. - Tytus Gerrish [more]
Unread 15-02-2007, 03:12
itsme itsme is offline
FRC #2217 (FOMH)
itsme is an unknown quantity at this point
Rule 7.3.2.3
I'm from team 2217 . We are a rookie team.
We have some difficulty understanding the rule concerning the starting conditions:
When the match starts - can a human player put the keeper on the arm or
do we have to program the robot so that it pick up the keeper ?
Unread 15-02-2007, 04:02
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Re: Rule 7.3.2.3
Before the match starts, members of the drive team will carry the robot out onto the field and set it in its starting position/location. You will then have the opportunity to load your robot with a keeper if you wish - this should be achievable without robot control, however - as you will not be permitted to tether or use the controls to setup the robot. Acceptable keeper starting positions are outlined pretty thoroughly in Rule <G04>, but basically boil down to that the keeper must be in the home zone and in contact with the robot. Once your robot is setup, all drive team members return to their alliance zone and await the start of the match.
Last year, we were given our starting game balls during staging in order to expedite the shift between matches, as some robots took time to be loaded with ten balls. I would expect that this year with only one starting object per robot you won't get it until you are on the field - much like two years ago when we started with a single tetra.
- Jeff
Unread 15-02-2007, 05:29
feliks_rosenber's Avatar
feliks_rosenber feliks_rosenber is offline
Félix
AKA: Mentor of Teams #2217 & #2669
FRC #2217 (FOMHA & KY Bots)
feliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the rough
Send a message via MSN to feliks_rosenber
Re: Rule 7.3.2.3
Ok, but then the robot exceeds the robot physical rules.
Is it allowed to exceed the dimensions before the beggining of the match ?
Unread 15-02-2007, 06:08
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Re: Rule 7.3.2.3
Yes, with conditions
7.3.2.2 Starting Conditions
<G04>
KEEPER locations - Each ROBOT starts the match in POSSESSION of a KEEPER. The
KEEPER does NOT need to be contained within the ROBOT'S starting volume, however it
must be in contact with the ROBOT and be entirely within the HOME ZONE.
Unread 15-02-2007, 07:53
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: Rule 7.3.2.3
The robot is not allowed to exceed the starting demenions until after the start of the game. The toroid is not considered part of the robot in starting configuration. The toroid must be in contact with the robot at the start and both the toroid and robot must be completely within the home zone to start the match. Hope that this helps.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 15-02-2007, 08:50
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Rule 7.3.2.3
As an example: We cannot start with the toroid on our manipulator, because doing so would make part of our robot (read: aluminum) extend past the 38" boundary. However, as long as the toroid is touching the robot, we are in possession. So, we are going to lay the keeper on the ground in front of (and touching) our bot, and write into the autonomous code for the manipulator arm to pivot down and pick up the keeper before going off to score.
Hi!
Unread 15-02-2007, 08:57
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Rule 7.3.2.3
We are planning on having our pneumatic system pressurized, with the manipulator in the "closed" position when the robot is off. The game piece will fit in the manipulator (and the manipulator will hopefully fit within the 38" limit), and when autonomous mode starts, the robot will make some interesting maneuver to extend the arm and flip the manipulator/game piece down into scoring position. Should be fun to see if our programming team can make it work....what do they have, 4 days?
Rule 8.4.1 Lil' Lavery Rules/Strategy 37 11-01-2006 20:46
Rule G11 and Springs Rule mtaman02 Technical Discussion 3 23-01-2004 17:43
Rule C1 Justin Stiltner Rules/Strategy 9 05-01-2003 22:59
Rule K3? Raul Rules/Strategy 9 05-01-2003 06:38
RULE Question. archiver 2001 7 24-06-2002 00:38
