Go to Post Since this thread doesn't seem to have quite enough numbers yet, here are some more. - William Frost [more]
Unread 15-02-2007, 07:45
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Re: Moving to a point between lights with autonomous
Originally Posted by dpick1055 View Post
The problem with attempting dead reconing based off where the lights start is that it is very hard to account for slippage of your wheels and what other robots will be doing. If your alliance has 3 robots going for the rack at once and you hit another robot on your way without some sort of feedback you will have no way of correcting yourself and getting back on target.
Dead reckoning doesn't mean just setting some motor outputs and waiting for a specified amount of time. Dead reckoning in this case refers to the process of estimating the position of your robot based solely on speed and direction of travel and time elapsed since the last known position. The "reckoning" part referes to the fact that you can't get new known position information based on the location of the rack. You can, however, account for wheel slippage by using accelerometers and a gyro, which track absolute--not commanded--speed and heading since you left where you know you were. This system can be very accurate if implemented correctly.
Robinson Levin
'... who are you, then?'
'I am part of that power which eternally
wills evil and eternally works good.'
Goethe, Faust
Camera tracking between two lights Ankush Dhar Programming 2 12-02-2007 23:44
Moving robot while tracking with camera questions... Steve Orr Programming 6 02-02-2006 22:24
Anybody have a code for an autonomous mode to go to the 50 point bar???? and... chaoticprout Programming 9 06-11-2004 12:22
Teams with 100 point average in Atlanta Qualifying rounds DougHogg Championship Event 0 21-04-2004 01:03
problems with receiving signals between radios (need help0 chrisw Technical Discussion 4 11-01-2002 10:35
