Go to Post In 2001 instead of staring at the field at the game I turned around and watched the people watch the field. All I could see was a mass of people from all corners of the world, eyes lit up, gears turning in their heads. That, to me, is FIRST in action. - Jessica Boucher [more]
Unread 14-02-2007, 17:06
|_-LuIz-_|'s Avatar
|_-LuIz-_| |_-LuIz-_| is offline
AKA: Inácio
FRC #1621 (Eniac Team)
|_-LuIz-_| is an unknown quantity at this point
Send a message via ICQ to |_-LuIz-_| Send a message via AIM to |_-LuIz-_| Send a message via MSN to |_-LuIz-_| Send a message via Yahoo to |_-LuIz-_|
Banebots Doubt
I was wondering which fuse should i use on banebots motor(MP-36064-540)???
Just asking that 'cause on FRC2007 Goods and Tips guidelines, there's a table that shows the current of this motor is 37A, but, on banebots' website it's providing the information that the same motor has a 42A, so now i dunno which fuse to use on it.
It's possible to fly without motors, but not without skills, knowledge and determination.
ENIAC team...#1621
Unread 14-02-2007, 17:20
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Banebots Doubt
We're using a 20AMP on our, and it hasn't tripped yet! You must remember that this is stall current, and when it stalls, it burns the motor up.... So better be safe than sorry and use the 30AMP. We used a 20AMP to save weight on the wiring.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 14-02-2007, 20:56
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: Banebots Doubt
i would use the 40 amp
Unread 14-02-2007, 21:09
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: Banebots Doubt
Why? Do you want to start a fire!?
Unread 14-02-2007, 23:38
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: Banebots Doubt
If you're worried about the motor then use a smaller fuse!! Better the fuse blow than the motor or wire burning!!
Unread 15-02-2007, 01:03
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Banebots Doubt
we have a 20 amp in ours, I sure hope it never sees more than 10 amps
Unread 15-02-2007, 08:17
Re: Banebots Doubt
Banebots lists the current at peak efficiency at 6+ amps. The 20 amp breaker should work for most designs. However, be aware that many teams are reporting that this motor is smoking when under heavy loads. It is essential for these motors to be operated in a range where the fan has adequate RPM to cool the internals. Plan accordingly.
Unread 15-02-2007, 08:26
MrForbes's Avatar
AKA: Jim
Re: Banebots Doubt
Now I'm really curious...where is this "fan" you speak of?
(yes, I have a 36mm BB gearmotor right here and I've been looking at it)
Unread 15-02-2007, 08:30
Re: Banebots Doubt
If you look at the slots in the side of the motor, you will see a white fan. The blades are on edge. When the motor runs the fan "throws" the air out through the slots and draws air in through the other holes in the motor.
Unread 15-02-2007, 08:44
MrForbes's Avatar
AKA: Jim
Re: Banebots Doubt
When I look in the motor of my new Craftsman cordless drill, I see a white plastic fan, as you describe. But when I look at a BB RS540 motor, I see no fan at all. Here are some pics taken thru the slot in the motor.
ID:	5094  Click image for larger version
Unread 15-02-2007, 08:48
Re: Banebots Doubt
Jim,
I could have sworn there was a fan. I will try to check tonight, we are not using the Banebot motors. The Fisher Price motors are a similar design and have an internal fan.
Unread 15-02-2007, 08:52
MrForbes's Avatar
AKA: Jim
Re: Banebots Doubt
The FP motor will fit the BB gearbox, eh? might be a worthwhile swap. Then again, I just ordered 4 more RS540 motors and pinions from BB, for $20 for all 4, plus postage.
Unread 15-02-2007, 08:58
Re: Banebots Doubt
We are using the FP in a custom transmission. We have used these motors for many years and are happy with the performance if you keep the fan turning and the ventilation holes open. We have smoked a few over the years. This years motor has an internal circuit breaker though. I am still researching this, we found it by accident over the weekend.
Unread 15-02-2007, 09:03
MrForbes's Avatar
AKA: Jim
Re: Banebots Doubt
heh....I guess it's better to find a breaker, than to find the magic smoke!
Unread 15-02-2007, 09:07
Re: Banebots Doubt
Not when the arm is half way up! We solder wires to the motor for best reliability but I may have damaged it when I performed the solder operation. It trips pretty easily and has a slow recovery. We will be testing our backup tonight (I hope) or tomorrow.
Banebots Red Wiring kiettyyyy Electrical 4 15-02-2007 03:54
Banebots Return policy fsracer General Forum 12 31-01-2007 08:36
42 mm Banebots Gearbox Hunter Motors 9 13-01-2007 21:52
I´m in Doubt...2x Balls tribotec_ca88 Rules/Strategy 6 13-01-2004 13:17
Gyroship doubt Daniel_H Programming 0 18-02-2003 13:37
