Re: pic: Team 195 driving base 2007
I think they are also taken on a new look this year. Nice rims I like the blue |
believe it or not the delrin is only in the temp chain tensioners...
all the black is simply ABS plastic P.S. the swirl finish looks really pretty black ;-) |
Meh, I never did like the efficiency of those crash shifters.
Either way, you guys are gonna rock this year. This base looks good, and a practice bot/full playing field doesnt hurt! (Any other college mentors feel like they got the short end of the stick when they left?) Last edited by Tom Bottiglieri : 15-02-2007 at 14:55. |
wow 6 wheels? how do you turn?
cant wait to see this at the scrimmage !!!
tom...you were holding them back...hahaha jk guys |
You lower the middle wheel by a small amount (usually 1/8" to 1/4") so that at any given time your wheelbase is small for easy turning, but you have the stability of a longer wheelbase. Only 4 wheels can contact the ground at any given time (unless you have VERY soft carpet)
#7
With any 4 wheel tank-drive wheelbase, long and narrow is much better at going straight, short and wide is better for turning. The problem with the short and wide is that it's easy to tip over in the forward and backwards because of the short wheelbase. The remedy is to take your long and narrow base and put a middle set of wheels that is lower than the rest. This gives you essentially two sets of "short n' wide" wheelbases that you rock between. This makes you hard to tip, but also makes it much more efficient to turn, and gets rid of the characteristic "hop" that many high-traction, 4wd robots have.
another version of the 6wd solution is to keep all the wheels on the same level and replace one or both of the outboard sets with omnis (see 488's robot this year) |
#9
I won't repeat all the arguments here, but you can find discussion about it here, and it would appear that a few of your mentors are quite familiar with 6wd systems. You'll also notice that most well-designed tank tread robots have a middle wheel that's slightly lower than the outer wheels, making it essentially a "lowered wheel" 6wd system There is nothing here that says this is the ONLY way to do 6wd. Your team is living proof of that. I'm just trying to present the reasoning behind the lowered wheel. Many MANY teams use this design, so they can't all be wrong. |
#11
http://www.chiefdelphi.com/media/photos/26869 We only been doing wheel for two year so I am no expert but this system works. it is lowering the center wheel a little. We did tank track before that and also had a center wheel http://www.chiefdelphi.com/media/photos/18792 I think our robots has proven to have power so what he is doing is a good way |
#12
In order to ensure better turning, the following relationship is key.
By lowering the center wheel, you effectively create two 4WDs with a shared center wheel. Each of these has a wheelbase roughly 1/2 of that of the same drivetrain with coplanar wheels. Also, closer the center of mass of your robot is to the center wheel, further it is away from the center of area of both of the wheelbases. Additionally, the traction and width factors should be the same as if you had a coplanar 6WD, and you still achieve many of the other benefits of a 6WD. (Thanks to Chris Hibner for this terrific white paper on the physics of turning with a 4WD). Last edited by Lil' Lavery : 16-02-2007 at 01:03. |
#13
Alright, I am going to use your team as an example. I can only assume and guess. I know you guys don't lower your middle wheels. Why? I have never been able to get a straight answer from anyone. You guys play around with your tread patterns a lot.
On the other hand, when you do a 6wd and don't lower your middle wheel, the robot is trying to turn on 6 different points. Depending on the friction you create with the wheel/tread you are using, it is very hard to turn unless you lower your middle wheel. While lowering the middle wheel, lots of team work on their CG. If the CG is low and the weight is distributed properly throughout the robot, while turning, the robot turns on 2 (middle) or 4 wheels (using only 4 different points to turn), creating less friction. At the same time, there are always 4 wheels touching the ground. I know wedgetop compresses, so if the weight is distributed properly, you get all 6 wheels touching the ground while going straight or back even if you lower your wheel. It also depends on the team how much they lower their middle wheels. I have seen teams do 1/16, 1/8, 3/16, 1/4, even 3/8 and lot of teams have been successful doing it too. I sure would like to know how does a team turn without lowering their middle wheels. If there is anyone out there with a proper answer with reasonings behind it, please post. Now back to topic... As always, 195's chassis looks awesome. I am digging those wheels. Can't wait to see you guys in person. Let's not burn a victor out right before the final match this time. =) |
#14
What I'd really like to see is an eight wheel drive, with 4 centralized drive wheels that are in contact with the ground all of the time, except when accelerating hard in one direction, or pushed from the top. The front 2 and back 2 would be raised up a bit (1/8" or so), be smaller (to reduce weight), and probably unpowered. This would have the benefits of a long drivetrain, be stable (none of the rocking back and forth I'm guessing you get with a 6WD), and have a more predictable center of turning. |
| pic: Team 195 Wheel | jjdebner | Robot Showcase | 7 | 12-02-2007 19:11 |
| pic: Team 195 base | jjdebner | Extra Discussion | 5 | 06-02-2007 22:39 |
| pic: 195 Drive Base | Tom Bottiglieri | Robot Showcase | 24 | 16-02-2006 12:50 |
| pic: Team 195 Teaser #3 | Sscamatt | Extra Discussion | 19 | 08-02-2006 01:13 |
| pic: Team 195 hanging | CD47-Bot | Robot Showcase | 12 | 02-03-2004 22:39 |
