Go to Post Why did they get rid of the headphone jack though? =p - sportzkrazzy [more]
Unread 14-02-2007, 10:20
CoasterFuelPhil CoasterFuelPhil is offline
FRC #1930
CoasterFuelPhil is on a distinguished road
Basic Math Help
Hi, this is my first post on Chief Delphi. my name is Phil Nguyen and I am on the team 1930, Delta Force.
I am having trouble with multiplying numbers and stuff. the numbers cannot be an int because we need it very precise.
PHP Code:
current_height=29.401*(pow((0.0049*((double)Get_Analog_Value(rc_ana_in01)) - 0.0044),-1.0895));
It doesn't work, not even somthing like:
PHP Code:
current_height = ((30)*Get_Analog_Value(rc_ana_in01));
I am getting a number like 18 thousand when the analog info is something like 200
We've tried using current height as a double and a float, same thing.
Unread 14-02-2007, 10:27
Re: Basic Math Help
How precise do you need this number?
If you need it in thousandths, just multiply everything by 1000 first, then deal with the decimal shift later. That way you can use only integer math and keep your precision. Remember, you only get a byte of resolution to drive your motors..
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
Re: Basic Math Help
My first thought would be to try something like this.
current_height = Get_Analog_Value(rc_ana_in01);
current_height *= .0049;
current_height -= .0044;
current_height = pow(current_height, -1.0895);
current_height *= 29.401;
Working with floats can be very confusing, since the default casting is (int). I always like to try it like this, until I'm sure my logic is correct. In fact, this may even result in less assembly instructions, although I'm not sure at all.
void function(void)
  function();
Unread 14-02-2007, 10:37
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Basic Math Help
what type is current_height?
18 thousand could be correct, maybe the analog input value is higher than what you think it is.
Try printing the analog value and the value*30, and compare them.
Also, I strongly recommend not using floats, they are very slow and memory intensive.
Unread 14-02-2007, 11:06
FRC #1930
Re: Basic Math Help
we're using an infared sensor to detect height, I'd like the height to be close to thousanths. yeah, I did do a printf and thats where I got the number 200 from.
Unread 14-02-2007, 11:22
Re: Basic Math Help
Assuming current_height is defined as a float, how are you printing the value?
This printf does not support printing of floats, so are you converting it back to an (int) to print?
By the way, floats, including doubles, on this PIC actually have less accuracy than a long.
Unread 14-02-2007, 12:18
FRC #1930
Re: Basic Math Help
printf("current_height: %u\r", current_height );
thats probably the problem
Unread 14-02-2007, 12:55
Re: Basic Math Help
Yes, printf does not support floats
Try this: printf("current_height: %u\r", (unsigned int) current_height );
I would strongly suggest not using floats, though.
Unread 14-02-2007, 13:39
buddy.smith buddy.smith is offline
Master Control
FRC #1795
buddy.smith is an unknown quantity at this point
Re: Basic Math Help
Okay, let's look at this another way.
Your analog sensor gives you a value of 0-255
Your motor takes a value of 0-255
So, why are you using a float?
At the worst case, you could use a look up table.
You have your complicated formula you want to use. Use your formula to make an array. Then, you just need:
myvalue = LookUpTable[GetAnalogValue(....)];
Make sense?
Or, you can forget about inches, and deal with everything in the domain of 0-255, whatever units they happen to be
Unread 14-02-2007, 15:30
Re: Basic Math Help
Actually, analog inputs on the RC are 0-1023 (OI is 0-255) unless you use a different ADC. Also, they are not trying to controll a motor, they want to calculate the height of something (arm?)
Unread 15-02-2007, 11:05
Master Control
FRC #1795
Re: Basic Math Help
I stand corrected.
Still, he does not need floating point for this.
(to the OP): Have you ever heard of "fixed point" math? Someone touched on it earlier - if you need .001 precision, then multiply everything by 1000. Keep in mind that at .001 precision, you can measure just one inch with your A/D....
ttyl,
--buddy
Unread 15-02-2007, 15:18
Cheezmeister Cheezmeister is offline
FRC #0871
Cheezmeister is an unknown quantity at this point
Re: Basic Math Help
Originally Posted by buddy.smith View Post
I stand corrected.
ttyl,
--buddy
Well, floating point is the most direct solution to the precision needed for complex formula. The values he starts with and the values he'll wind up with ought to be ints, but that doesn't mean that everything in the formula can necessarily be rounded.
I mean,
current_height=29.401*(pow((0.0049*((double)Get_An alog_Value(rc_ana_in01)) - 0.0044),-1.0895));
Shouldn't be turned into
current_height=30*(pow((0*((double)Get_Analog_Valu e(rc_ana_in01)) - 0),-1));
You'd always get a divide by zero =P!
However you might be right in that floats/doubles aren't the tools for the job...I can't say; I'm not up on PIC architecture
Unread 15-02-2007, 17:41
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Re: Basic Math Help
I've never used floats, we always use doubles. They get printed with %dl, and they operate very similarly to floats
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 16-02-2007, 00:31
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Re: Basic Math Help
Doubles are even more memory-intensive than floats on the PIC18F (well, on any architecture, but especially so on the PIC). Using them probably is a bad idea, I doubt you'd ever need that precision for FIRST. Also, double use the %lf token, for "long float." I don't think %dl has the meaning you think it does.
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 16-02-2007, 02:57
FRC #0701 (RoboVikes)
Re: Basic Math Help
There is no reason to use floating point numbers,
Why not do this:
current_height=
(294010* pow( (49*(Get_Analog_Value(rc_ana_in01)) - 44),-10895)  )  ) / 10000 );
You will need to use a unsigned int for the first param of the pow function
to keep it from overflowing
Team 701
Help with math Termite233 Math and Science 4 12-07-2005 04:41
basic pneumatic help needed Anton Programming 4 10-02-2005 16:02
Help programming in Visual Basic xxlshortys Programming 0 06-04-2003 08:54
Math Help!!! Leon Machado IV Chit-Chat 7 16-11-2001 19:38
