Go to Post If you ever find yourself thinking that you are the most brilliant person in a situation, you are doing something wrong. - EricVanWyk [more]
Unread 14-02-2007, 11:20
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
HELP: How do i make Arcsin in MPLAB
Hey
An important question for our team:
How do i make arcsin in MPlab, not using a 1 to 180 loop checking every angle and finding the closest one to the value i need?
thanks, the Black Knights
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 14-02-2007, 11:57
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Re: HELP: How do i make Arcsin in MPLAB
Should be in <math.h>.
#include <math.h>
double asin(double x);
float asinf(float x);
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 14-02-2007, 12:18
foote stepped in
AKA: E. Foote
FRC #0868
you could make a lookup table... a large array usually can do the trick. It'll save you the processing power from not using a double, but it'll eat up memory pretty quickly.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 14-02-2007, 12:28
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
I would try and google arcsin approximation and find one that only involves rational expressions, to limit the amount of floating point math.
Unread 14-02-2007, 17:48
Jared Russell's Avatar
Taking a year (mostly) off
There was a whitepaper on Delphi a couple years ago about CORDIC trig implementations...you should look it up.
Unread 15-02-2007, 15:22
Cheezmeister Cheezmeister is offline
FRC #0871
Cheezmeister is an unknown quantity at this point
#include <math.h>
You don't know how long we were pulling our hair out last year because it couldn't parse "arcsin(x)" (not to mention me repeatedly telling others that "1/sin(x)" would NOT do it) ;D
Unread 15-02-2007, 15:33
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
This is humerous, but likely the result of what I am informed is another case of poor american practice (or practise). arcsin is usually written sin^(-1), and this can cause confusions, since x^(-1) would in fact equal 1/x. However, in the case of sin^(-1) (and other inverse trig operations), it just means arcsin.
I could be wrong about the fact that it's american in origin, but I imagine that's the root of your problem.
Paul
Unread 15-02-2007, 15:39
fallen751 fallen751 is offline
FRC #2052
fallen751 is an unknown quantity at this point
If your range of data is within a pretty reasonable small area like (0, pi/2) you could try doing a fifth or sixth degree taylor polynominal instead - it might help with the processing power. then again, if your not performing many other calculations the arctanx function should work fine. (remember it returns radians.)
MPLAB 7.20 Help please? groovy69 Programming 14 22-01-2007 02:00
Help with MPLAB burningpig Programming 9 17-01-2007 13:10
Help how to make a forum was217now1509 Website Design/Showcase 12 25-02-2005 22:37
MPLAB IDE HELP Idaman323 Programming 2 16-02-2005 18:01
Arcsin Calculation Algorithm Leo M Technical Discussion 11 05-11-2001 08:31
