Go to Post Adding an ounce or two of shields is way easier than filling out the mountains of paperwork for that one impatient person to stick their arm into the robot reaching for who knows what only to have their fingers meet up close and personal with a gearbox. - artdutra04 [more]
Unread 15-02-2007, 15:33
bruss6's Avatar
bruss6 bruss6 is offline
FRC #0843 (Wildcats)
bruss6 is an unknown quantity at this point
custom PWM cables
Our team needs longer pwm cables so we were wondering if it is legal solder some custom pwm cables to make them longer? We were planning on using somehting along the lines of telephone wire.
Unread 15-02-2007, 15:38
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: custom PWM cables
As far as I know it is. Several PWM wires on our eletronics board are soldered to make longer.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 15-02-2007, 15:44
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
The parts flowchart (Man8 page 19) says that it's legal.
So yes, go ahead.
Unread 15-02-2007, 18:07
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
For those that don't want to do that you can just use 2 cables plugged into each other and tape them so they don't come apart.
But yes, you can cut and solder them.
Unread 15-02-2007, 18:10
dtengineering's Avatar
AKA: Jason Brett
It is also possible to buy bulk servo cable and fittings from Digikey or other on-line electronics shops to manufacture your own custom one-piece cables.
Jason
Unread 15-02-2007, 18:31
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Jason
This is what we do on Team 95. In fact, we usually only use the kit pwm cables for prototyping and pit repairs, everything else is custom pwm cables cut to length to make the wiring neater.
For our long runs this year, we used Cat 5e cable and some RJ45 to 0.1" pin connector breakout boards from SparkFun. I'm rather happy with how that worked out.
Unread 16-02-2007, 08:33
Any of these work but...
I frown on solid wire used on moving devices. The vibration can cause them to fail and you know what Murphy says about this...It will happen during the last match of the finals. Extensions are the easiest followed by soldering and insulating followed by buying the right stuff and making them yourself. If you are planning on coming back next year, get the pins and wire and a nice crimper from Digikey. It is the best long term solution.
Custom PWM Cables and R69 FreakyAntelope Electrical 13 15-01-2007 15:17
PWM Cables Alex Cormier FIRST Tech Challenge 15 13-08-2006 09:48
PWM Cables zachriggle Electrical 3 04-02-2006 13:54
Bad Pwm cables Greg Needel Electrical 7 18-01-2006 23:13
The PWM Cables amateurrobotguy General Forum 1 22-02-2005 17:42
