#16
Re: Power distribution block mounting
Jorge,
The DIN rail in your picture is definetely different thant ours. It appears you were shipped the wrong one by mistake. I would get a hold of FIRST parts right away. It might be too late for you to ship but I am sure you should be able to add it at your first regional. Our rail has slotted mounting holes. |
#17
The rail you showed looks a lot like the IGUS rails we're using for our arm, are you sure that there isn't any other rail in your kop?
#18
Thanks for the help guys, we should get to ordering some rails. |
#19
We're gonna have to use the robot with the feed wires going directly to the hi-amp breaker and the ground common for now. Were gonna leave it all setup for when we get the DIN Rail in the regional (with the holes and the wires cut to the measure).
Can anyone tell me the distance between the edge of the DIN Rail to the nearest setup hole and the distance between each hole and how many of each of the red and black terminal are the minimum REQUIRED for the distribution block? Thanks to everyone that helped us in any way in this thread. |
#20
Guys,
I would assemble the blocks and hold them together with electrical tape or something and then wire as normal. Then all you have to do when you get the right rail is just slip it in and mount it up and remove the tape. No wasted wire or time. |
#21
I mounted it temporarily using zip ties and electrical tape, hope we can install it neatly at the regional!. Thanks again
#22
Anytime, Good Luck! What regionals will you be attending?
#23
Our team will be attending the Boilermaker Regional in West Lafayette and the Buckeye Regional in Cleveland. Gonna put it in my sig =)
| Question:Power Distribution Block | Pavan Dave | Electrical | 35 | 20-03-2007 20:10 |
| Power Distribution Block Mounting | Karma | Electrical | 5 | 23-01-2007 02:20 |
| Power distribution Block? | Pontchartrain | Electrical | 3 | 27-01-2006 07:30 |
| Stinger Fuse Block and Power Distribution Block | Don Wright | Electrical | 2 | 30-03-2004 10:45 |
| Power Distribution Block | DukesElectrical | General Forum | 0 | 09-02-2004 23:48 |
