Go to Post As you get more into your years in FRC, you start becoming friends with more people. You should try it out. Robotics people are pretty nice. - [more]
Unread 14-02-2007, 22:16
Craig1989 Craig1989 is offline
FRC #0539
Craig1989 is on a distinguished road
The 72 x 72 Box
I am fully aware that the robot must not extend more than a 72 x 72 inch area at any point during the match. The way our robot is designed when the arm is fully extended at horizontal it will break this rule; however the arm is never fully extended unless we try to reach the top spider leg, in which case it does not break the 72 x 72 rules
However, recently I've read posts on a 72 x 72 inch box. What is the requirement of this box and what does the robot have to do within it to prove it 'fits'?
Thanks.
Unread 14-02-2007, 22:22
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: The 72 x 72 Box
The GDC has answered at least one question on this already in the official Q&A forum. Look here. And here. And here.
How do you 'prove' your robot fits? Hmmm.... looks like it won't be part of inspection -- see the inspection checklist. No reference to <R12> there.
The referees will be looking for robots that extend too far on the field: "if a device has a horizontal dimension more than 102" and it is used outside the Home Zone, then it will automatically be assessed as a violation of Rule <R12>. In all other cases, each robot will be assessed in real time as they operate outside the Home Zone to identify any confgurations in which they violate the dimension constraints specified in Rule <R12>. A robot/device that has the physical potential to violate the dimension constraints, but does not actually do so during the match, would not be in violation of Rule <R12>."
Richard Wallace
since 2003
Unread 14-02-2007, 22:39
FRC #0539
Re: The 72 x 72 Box
Ok so there is no box we have to fit into at inspection.. that answers my question. Thank you
I didn't mean prove to sound like that, we are positive that our robot fits into the 72 x 72 dimensions. Our arm extends and withdraws as it raises to prevent this problem. I was just checking that we weren't physically going to be placed into a box and asked to turn our turrent round with the arm fully out in all directions.. This naturally would create a problem..
Thanks for clearing that up.
Unread 15-02-2007, 07:59
BobC's Avatar
BobC BobC is offline
Big Daddy
FRC #0176 (Aces High)
BobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to all
Send a message via AIM to BobC
Re: The 72 x 72 Box
Thanks.
Think of it as being in a 72 x 72 by infiniti tall test tube. You can go as tall as you want as long as you stay in the tube.
FIRST Robotics is like NASCAR for Geeks.
1999 National Champions
Unread 15-02-2007, 08:39
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Re: The 72 x 72 Box
Uhm, i think that there is something wrong there. When has there ever NOT been a box that you had to fit into. Im not 100% but i think there will be a box. You HAVE to fit into starting position, which is what the box is.
Min-Max to the Max!
Unread 15-02-2007, 08:42
Taylor's Avatar
Taylor Taylor is online now
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: The 72 x 72 Box
Yes, but this box is 28X38 and tests your starting configuration. After the start of the match, you may extend past these boundaries.
The "72X72 box" is purely conceptual.
Hi!
Unread 15-02-2007, 20:58
BobC's Avatar
Big Daddy
Re: The 72 x 72 Box
There is an inspection box that your robot must fit into for the start of matches. The box will be 28 x 38 by your height depending on weight.
Unread 15-02-2007, 22:30
Gdeaver Gdeaver is online now
FRC #1640
Re: The 72 x 72 Box
This rule puts a burden on the refs. I've seen several designs that could easily extend beyond the box.
Can you mount the tires directly on the gear box? free_rider_151 Motors 9 13-01-2007 09:04
What was in the 5th box that the rookie teams got? Jack21 General Forum 3 12-01-2004 03:55
What's in the BOX? Mark Jones General Forum 65 11-01-2004 10:51
Height of the box stack from the floor tenfour General Forum 4 07-01-2003 10:26
Weird Moving-Box (or any Big Box) uses Kristina Chit-Chat 5 25-06-2002 17:19
