Go to Post FIRST Robotics Competition could NEVER, EVER, EVER feature aquatic robots. - dlavery [more]
Unread 15-02-2007, 21:36
nreyesciena's Avatar
nreyesciena nreyesciena is offline
Electrithingy
AKA: Nelson Reyes Ciena
FRC #1872 (Yellow Fever)
nreyesciena is an unknown quantity at this point
Send a message via MSN to nreyesciena
NiCad Battery for decorative use?
Is it legal to use any extra NiCad backup batteries to power decorative lights in the console case?
"We have journeyed where none have been before. Now we return to ensure that none follow."
2006: Florida Event- Rookie Inspiration Award
2007: Boilermaker Regional and Buckeye Regional Events
Championship Event
2008: Florida Regional Event
Unread 15-02-2007, 21:52
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: NiCad Battery for decorative use?
No, anything on the OI side has to be powered by the OI, except the Chicklets.
Unread 15-02-2007, 22:33
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Don't connect them to the OI through the joystick ports. If it doesn't connect to a joystick port, it's not covered by the no-external-power rule (e.g. laptops attached to the dashboard port have batteries).
Originally Posted by <R83>
All equipment connected to the joystick ports of the Operator Interface must be powered solely through the power available through the port. External power sources of any type are not permitted on any equipment connected to the joystick ports. Portable computing devices can not be connected to joystick input ports on the Operator Interface. Powerpassive devices (e.g. joysticks that draw their power solely through the Operator Interface joystick port) are permitted. The one exception to this rule is Innovation First Incorporated USB adapters (IFI Part Number USB-CHICKLET) may be used to connect USB devices to the joystick ports of the Operator Interface. If used, this USB adapter must be powered with a 7.2V battery similar to the back-up battery. Teams can not use power from the competition port or any other source to power the USB adapter. The USB adapter must be positioned within the OPERATOR CONSOLE so that the indicator lights may be seen during inspection and operation in a match.
And it should go without saying that you don't want to install large green lights in places where robots can see them.
Unread 15-02-2007, 22:35
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
yes, you can have things powered like decorations or computers by batteries.
Note, I don't think lighted consoles are a good idea. The drivers have enough sensory input without adding other distractions. Also carrying around heavy consoles can be a real drag after a long day of competition.
Unread 16-02-2007, 12:21
Electrithingy
THe decorations werent gonna be connected to the joystick ports or anything but okay I understand the point. Anyways on the heavy aspect i'm gonna be the operator and it isnt as heavy as we thought it would be so weight isnt really an issue. Thanks for the replies!
Championship Event
Unread 25-02-2007, 00:21
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
'Power Passive'....
Say I have a bunch of 12V devices on my OI... And going between the device and ground I have a little 5V $2.79 RadioShack relay. Can I use the output pins on Port 3 to allow power though to the 12V devices? No (Very, very, very, very little) power is being consumed, the relays are simply getting a signal to allow power through.
Is this legal?
Jacob
Unread 25-02-2007, 00:55
That doesn't sound legal. The external 12 V is connected to whatever load you've got, and the relay is connected to the joystick port and the 12 V supply (though one feeds the coil and the other is switched).
Unread 25-02-2007, 12:05
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
'Power Passive'....
Is this legal?
Jacob
No. There are two relevant postings on FIRST's Q&A forum.
See this one and this one.
If they won't allow an opto-coupler, they aren't going to allow a relay.
--Dave
7.2v nicad battery wireing? hotcheese Electrical 2 16-02-2005 15:25
Looking for webspace for personal/FIRST use. Madison General Forum 5 11-04-2004 22:22
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
is anyone wanting a lot of lights (decorative) on the robot? archiver 2001 5 24-06-2002 00:09
Battery power for OI? P.J. Baker Technical Discussion 6 21-06-2001 14:46
